06-24-2012, 09:28 PM | #1 |
v It bites.
Drives: 2011 IBM 2SS/RS Join Date: May 2008
Where is your oil pressure at? (Cammed)
Curious where you guys with cammed cars are running?
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit. |
06-24-2012, 09:31 PM | #2 |
Drives: Florida Speed & Power Join Date: Jan 2011
I hover just over 30 or so
06-24-2012, 09:38 PM | #3 |
v It bites.
hmm, I seem to idle around 35-40.
While in motion the gauge is directly between the 30/70 hash mark. It seemed a bit high, but I wasn't sure if that was influenced by the cam or melling pump.
2011 2SS/RS
06-24-2012, 09:43 PM | #4 |
Drives: 2015 c7 Join Date: Nov 2009
middle of the gauge. its known the after market pumps run higher
06-24-2012, 09:47 PM | #5 |
v It bites.
middle of the gauge is 30 (I believe)... I idle there, but in motion I am at 50 and sometimes higher.
2011 2SS/RS
06-24-2012, 09:53 PM | #6 |
Drives: 2015 ZO6 3LZ Stage 2 A8 Join Date: Nov 2010
06-25-2012, 08:12 AM | #7 |
That's where mine runs. I think its the Melling Hi-Vol pump. I'm never below 30.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears 476 rwhp/440 rwtq (sold) |
06-25-2012, 08:25 AM | #8 |
Drives: 2010 CAMARO SS Join Date: Apr 2010
cammed/blower ...stock l99 oil pump,,,,at idle cold 45...at idle warm 40
06-27-2012, 02:50 PM | #9 |
Drives: 2010 Camaro 2SS Join Date: Apr 2011
I will run below 30 at idle sometimes. Almost down to what I would guess is 20. When I first crank over and driving around 40-50 usually.
It is a ported performance GM LS5 oilpump. My first oil pump died/crapped out. Factory defect. ** Thank you Hendrick Chevy for sticking me with the repair and bill ** |
06-27-2012, 04:24 PM | #10 | |
06-27-2012, 05:02 PM | #11 |
Drives: 2010 Black M6 RS/2SS Join Date: Oct 2009
Mine is like 31-32psi Oil, Coolant 186* and Oil temp 215* with a Melling 10295 hi pressure oil pump
10 Blk/Blk RS/2SS w/CGM Stripes
ADM H/C/I M6 480rwhp 435rwtq FE4 LCAs w/Pfadt ZL swaybars Diff bushings Trailing arms Drop springs |
06-28-2012, 03:41 PM | #12 |
06-28-2012, 04:37 PM | #13 |
Drives: 2010 M6 2SS Join Date: Mar 2011
Exactly the same as it was with the stock cam. Idles with a little more pressure now because it's idling at higher RPM.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension |
06-29-2012, 12:03 PM | #14 |
Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
Mines around 30 hot as well.
10.91 at 122 H/C stock block N/A
