04-30-2011, 11:19 PM | #1 |
Drives: 2011 black 1ss Join Date: Jan 2011
afm disable tune
are there any box tunes that disable the afm and can be changed back to stock for dealer visits and changed back to tune? is the hypertech any good? its for a 2011 l99
05-02-2011, 08:41 AM | #2 |
Drives: 2011 Camaro SS Summit White Join Date: Apr 2010
Sorry, the only way to disable the afm, as far as I know anyway, is to perform an LS3 conversion. This means changing out the lifters etc. Like I said I don't believe afm can be disabled with a simple tune, however, I really wanna get rid of it just as you do, so
I'll keep looking. |
05-02-2011, 08:43 AM | #3 |
Drives: 89 IROC 350 Join Date: Mar 2009
Not true. It can easily be tuned out. Also no reason to bounce back and forth. The dealer would know if they checked anyhow so why bother. You can't fool them. The computer logs everything. My guess is theyd never notice unless the looked.
Just tune that sucker and enjoy! The LS3 conversion does away with the VVT not the AFM. The AFM is computer controlled. |
05-02-2011, 09:29 AM | #4 |
Drives: 2010 Transformer 1SS Camaro Join Date: Nov 2009
The Diablosport Predator that I have seen for sale in the used section will do it!! Be advised that the word is that a dealer can tell the number of times the ECM has been flashed. Although, I have yet to see anybody refused warranty work while they changed back to the stock tune before going back to the dealership for warranty work. It is your call on what chances you want to take though.
05-02-2011, 11:59 AM | #5 | |
I offer these with a Free tune for simple bolt ons, then fully support any future part purchases from us with FREE tunes as well. Ted.
www.jannettyracing.com
05-02-2011, 07:12 PM | #6 |
Senior Member
Drives: 2010 Camaro 2SS Join Date: Oct 2008
How much? I have done the muffler delete and added a CAI. I mainly just want to eliminate the drone I am getting. Would like to try a tune prior to adding mufflers.
Rally Yellow 2SS,Polished 20's
PICKED UP ON 5/12/09 #4835 |
05-02-2011, 07:15 PM | #7 |
Senior Member
What about the SF3? Doesn't it disable AFM and allow trans tuning as well?
05-02-2011, 07:18 PM | #8 | |
Drives: 2010 Camaro 2SS/RS White S/C Join Date: Aug 2010
True, mine is disabled, my car has gone to warranty issues with no problem.
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty |
05-02-2011, 09:33 PM | #9 |
When I removed the AFM through a tune last year, it stopped all drone with your setup. No issues from that point at all. Before, my head almost split one day when accelerating during highway speeds. The tune is worth it.
05-03-2011, 07:20 AM | #10 | |
The SF3 does not have custom tunes for mod parts, only can tunes for stock vehicles and it cost nearly the same. Ted.
05-03-2011, 11:43 AM | #11 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
I put Solo-performance axle back J-pipes on my L99. It's the same as a muffler delete but no droan- Best of both worlds. I didn't want to loose my power train warranty with a tune.
05-03-2011, 12:07 PM | #12 |
Senior Member
Which tune did you install?
05-03-2011, 12:10 PM | #13 |
Senior Member
Ernie, do you have an L99? I thought you had the LS3.
05-03-2011, 01:01 PM | #14 |
I have an L99 and had Ted set up the tune with the SCT3 tuner he sells. It was incredible for a million reasons. That tuner (and yes, it goes back to stock) with Ted's tuning (his support is top notch too) and you will get everything you are looking for plus a TON of power increase!
Similar Threads | ||||
Yellow Lexus Type Fog Lights? | phenixdragon | Cosmetics and Lighting Modification Discussions | 37 | 05-21-2017 10:49 AM |
JANNETTY RACING UPDATED CUSTOM TUNE INSTRUCTIONS | JANNETTYRACING | Tuning / Diagnostics -- engine and transmission | 158 | 04-12-2014 08:27 PM |
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 250 | 04-01-2014 10:40 AM |
Undetectable Tunes - What You Should Know | kelley@vectormotorsports | V8 Bolt-Ons & Tunes | 159 | 09-18-2009 02:18 PM |
LS3 goes 11`s Bonestock! | GMRULZ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 12-08-2008 09:10 PM |
