JDP Motorsports
Old 10-25-2015, 10:26 PM   #1
DEKA
Drives: Silver, manual, steel wheels
2010 LS P0008 code 125k miles SFV
Title says it all, two mechanics diagnosed it p0008 but won't do the work because of their inexperience with this engine. I need the best price possible in West SFV. Vehicle shakes and is mostly not drivable. Any help is appreciated.
DEKA is offline   Reply With Quote
Old 10-26-2015, 10:35 AM   #2
fradaj
Drives: RS
What is p0008?
fradaj is offline   Reply With Quote
Old 10-26-2015, 10:50 AM   #3
clashley1976
clashley1976's Avatar
Drives: 2011 Camaro 2LT RS M6
That's probably a timing chain issue. If your mechs don't know the LLT very well, get to a GM service center.
Sent from my SM-N900V using Tapatalk
-Cameron Lashley
Albany, GA
2011 Camaro 2LT/RS 3.6L M6 Summit White w/silver rally stripes
CAI intake, VTC, VMax PTB, VMax Iceolator, Apex intake scoop, Roto-Fab washer bottle relocate
Build Journal: http://www.camaro5.com/forums/showthread.php?t=419992
clashley1976 is offline   Reply With Quote
Old 10-26-2015, 04:04 PM   #4
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Definately sounds like the timing chain. Best to get it to a shop that can change it out.
http://www.obd-codes.com/p0008
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan coil overs, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Dynamat, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 10-27-2015, 03:02 PM   #5
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Check into a low mileage used engine.
Recycled Part
2011 Chevrolet Camaro Used Engine Assembly
Engine Assembly NR-CT- 125X125X110X120X115X115
SKU: ~114151306
State: TX
Mileage: 66k
Price: $2,600.00
https://www.lkqonline.com/#!/2010/Ch...digit-opt-LLT/
etmx183 is offline   Reply With Quote
