Jason 98 TA
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 07-21-2018, 02:01 PM   #1
xstuntman
Drives: 2012 2LS Camaro LFX
shop fans
Looking for a little advice here.
Moving into my new shop yesterday and outside temps at 109 degrees. All steel and insulated 24x30, 9x7 garage door and a 48" wide man door. Sure need some air movement and the old box fan from the work room isn't cutting it.
I'm considering a 42" belt driven fan with a cost of $329 at HDepot but that maybe overkill? Four out of five stars doesn't exactly give me confidence for that price either.
Looking forward to 111 on Monday. Gotta love west Texas summers.
Caddy for life at Bushwood Country Club.
xstuntman is offline   Reply With Quote
Old 07-22-2018, 02:23 AM   #2
Bandit63
Bandit63's Avatar
Drives: 2011 Camaro SS
I would get a 1800btu air conditioner
MRR M228 wheels, Circle D 3200 stall, 3.91 gear, Texas Speed vvt 3.2 cam, CHE rocker arm bushings, Texas Speed headers, no cats
Bandit63 is offline   Reply With Quote
Old 07-23-2018, 10:07 PM   #3
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Bigassfans.com
Orange Krush II
1LE Front sway bar with DSE Sway Bar Links, Trailing Arms and Toe Rods, Splitter, and Axles, 14/15 Heat extractor, shocks and struts, Suede Flat bottom Steering wheel, short throw shifter with the Pegasus rear poly shifter mount, diffuser with dual mode mufflers, ZL1 Rockers, Belly Pan and pedals, Z/28 Intake, UCA Bushings,and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, C7 Z06 Vented Piston Calipers with CTS-V Rotors, PAFDT Solid Cradle bushing, 32mm JPSS Rear Bar, and Skip Shift eliminator. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 17/8 LTs.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
