02-02-2019, 09:05 AM | #1 |
Drives: 2014 2SS RS 1LE Join Date: Jan 2014
fuel system advice needed please
hey everyone, I'm getting ready to purchase a fuel system. My setup is a d1x procharger and cenrti cam. I'm pretty set on fore innovations dual pump with -8 feed and return. my question is do I get the system with the fuel rails routed in series and the regulator after the rails? Or do I get the system with the fuel rails routed in parallel and the regulator before the rails? Also wondering if I should get the FC2 or FC3 controller. Any advice from someone with experience is greatly appreciated,
02-02-2019, 09:43 AM | #2 |
Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
Agp fore duel 450 kit
Sent from my SM-N950U using Tapatalk |
02-02-2019, 10:56 AM | #3 |
Drives: All things Turbocharged Join Date: Dec 2010
What he said.
We do the regulator before the rails and a few other little tricks to majorly cut down on the cluttered fuel lines running everywhere. |
02-03-2019, 04:05 AM | #4 |
Drives: 2010 2SS/RS Join Date: May 2010
Why do people do the regulator after the fuel rails like this then?????
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned| God is too good! I don't deserve it, but I sure will accept it!!! |
02-03-2019, 12:05 PM | #5 |
Old fashion thinking. LOL
That design has merit theoretically and if your lines or rails were not big enough it would be necessary. Like you can't flow all of the fuel needed through one rail type thing, then you have to put a line to each rail, etc. That's just never actually the case in these cars, all the aftermarket rails have HUGE passages and -8 line at pressure can feed an unreal amount of fuel. As the years go on that old wives tale keeps getting disproved to higher and higher power levels. Not long ago people were sure you'd need -10 AN feed line for cars over 1000whp. LOL. We all know stock fuel line will support that now. Monkey see, monkey do, in the world of car hacks. Mythbusting is my favorite. |
02-04-2019, 07:08 PM | #6 |
I just checked out your dual pump setup, think it's much better for my goals. If I get the billet fuel rails do I need an aftermarket intake manifold?
02-04-2019, 09:52 PM | #7 |
Drives: 2010 SS Join Date: Feb 2016
1LE, I used my stock rails and my fab guy tigged -10 fittings on them. I go pump -> filter -> regulator -> rails. I did -10 feed and -8 return with twin TI pumps. I like the look of the aftermarket rails but I didn't like the cost.
White 2010 SS
Huron twins 4l80 conversion |
02-05-2019, 04:16 PM | #8 |
02-06-2019, 07:58 AM | #9 | |
We have seen high powered engine failures when a fuel system was not designed properly by starving 1 or more injectors. There are lots of dynamics happening in the fuel rail, multiple pressure waves as the injectors open and close, fuel being consumed before it gets to the last injector in line etc. This way above, every injector is guaranteed the same opportunity to deliver the same amount of fuel. Just because someone is getting away with something doesn't make it right or the new way of doing things. An EGT sensor at every exhaust port will dispel any so called mythbusting. We needed -10 lines when we were running 7 PSI of fuel pressure on carbureted 1000 HP combinations, as pressure goes up so does flow, our current fuel systems are operating on 60+ psi if done correctly which allows us to feed nearly a 1000 HP on a -6 line although risky and I wouldn't do it.. You also have to take in to account fitting orifices, and bends both of which can take a -8 system to its knees, the system is only as good as the smallest hole. 45 degree and 90 degree fittings reduces flow vs a straight fitting. Talk to Fore innovations/Aeromotive/Magnaflow etc directly for real data on fuel systems. When it comes to fuel systems doing the bare minimum is Russian roulette. Food for thought. If you need help designing a fuel system for your car please don't hesitate to call me 203-753-7223
www.jannettyracing.com
02-06-2019, 09:14 AM | #10 | |
We recommend the Fore 43-501 dual pump set up with stock rails. Just make sure you select an upgraded pump like the 267s if you want to run E85. Also, I would recommend the FC3 controller and hobs switch. It's all plug and play and easy to use. If you need injectors we have you covered as well. We always take care of board members. |
02-07-2019, 09:03 PM | #11 | |
Drives: 2011 2 ss/rs Join Date: Jan 2014
02-08-2019, 05:33 AM | #12 |
Thanks for the advice everyone, I appreciate it.
