Old 07-16-2021, 10:34 PM   #1
sanacm
Drives: 2011 Camaro LS, 2015 Camaro convert
Codes P0056,P014A,P0158,P0161
I'm getting these codes, temporary and permanent on my 2015 Camaro convertible with 22K miles.
P0056:Heated O2 sensor heater control circuit Bank 2 Sensor 2
P0014A: Sensor Delayed response -Rich to Lean - Bank 2 Sensor 2
P0158: O2 Circuit High Voltage - Bank 2 Sensor 2
P0161: O2 Sensor Heater Circuit - Bank 2 Sensor 2
Do you think replacing the O2 will solve the problem?
sanacm is offline   Reply With Quote
Old 07-17-2021, 06:40 PM   #2
Raceonedge
Drives: 2013 Chev Camaro LT2 RS
Yes it will fix it. Looks like your 02 sensor has checked out lol!
Raceonedge is offline   Reply With Quote
Old 07-18-2021, 10:25 AM   #3
Car Nation Videos
YouTube-Car Nation Videos
Car Nation Videos's Avatar
Drives: 2010 Chevrolet Camaro
Change your O2 sensor and that should fix your problem.
Car Nation Videos is offline   Reply With Quote
Old 07-18-2021, 10:49 PM   #4
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
Agreed. Sounds like O2 sensors. Change all 4
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
Old 07-27-2021, 09:18 PM   #5
sanacm
I went under the car to replace the O2 sensor. All 4 wires were cut. I knew I was replacing the right one. So the O2 was good. I couldn't believe that it would only last 22K miles. Now the mystery is how did the wires get cut? It wasn't a clean cut. Different lengths.
