02-17-2017, 06:19 PM | #1 |
'It's an experiment'
How I added a LFX LLT Electric Vacuum Brake Booster Pump
I have the details on my build thread, but I'll post the relevant parts here:
Pump and Hose (with part numbers): http://www.camaro5.com/forums/showpo...postcount=1089 Male connector: http://www.camaro5.com/forums/showpo...postcount=1091 External Fuse Box with relay: http://www.camaro5.com/forums/showpo...postcount=1094 6061 Aluminum for custom bracket (thanks to alice in the v6 section!): http://www.camaro5.com/forums/showpo...postcount=1102 http://www.camaro5.com/forums/showpo...postcount=1103 http://www.camaro5.com/forums/showpo...postcount=1104 Where to mount pump: http://www.camaro5.com/forums/showpo...postcount=1106 http://www.camaro5.com/forums/showpo...postcount=1113 Hose setup: http://www.camaro5.com/forums/showpo...postcount=1114 http://www.camaro5.com/forums/showpo...postcount=1115 Harness I made with the programmed micro-controller: http://www.camaro5.com/forums/showpo...postcount=1118 http://www.camaro5.com/forums/showpo...postcount=1119 Vacuum Pump test with Video! http://www.camaro5.com/forums/showpo...postcount=1120 Hose Routing: http://www.camaro5.com/forums/showpo...postcount=1121 Why: https://www.camaro5.com/forums/showp...postcount=1124 Startup: https://www.camaro5.com/forums/showp...postcount=1125 Works great! I have a VVT SS1 cam and sure, will get vacuum eventually, but that cold startup, this solves the problem. All GM parts (hose and pump) and these are from an LLT/LFX Gen 5 Camaro! Give credit where credit is due: http://www.camaro5.com/forums/showthread.php?t=382917 -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 Last edited by hammdo; 03-06-2019 at 12:47 PM. |
03-10-2019, 10:40 AM | #2 |
Drives: Camaro Join Date: Oct 2018
Thanks don. Going to look over your links and research this. Been looking for something similar.
