Old 08-14-2019, 03:42 PM   #1
camaro528
camaro528's Avatar
Drives: 2015 V6 Camaro
What's the Core Charge from GM direct??
Just trying to get the quad tip REAR DIFFUSER for my 2015 Camaro v6 (part#22829477 from gmdirect.com) but what the hell is the "core charge"they add on too your total $??? Also seems like everyone gets these diffusers cheaper, any other website suggested???
camaro528 is offline   Reply With Quote
Old 08-14-2019, 04:05 PM   #2
Welker2
Ret AF, cancer survivor
Welker2's Avatar
The core charge is for your old diffuser; once the recieve your old one, they will return the core charge. If you don't send them your old one, they'll keep it.
Old 08-14-2019, 04:06 PM   #3
camaro528
camaro528's Avatar
Oh I see....my old one has minor damage (dent) will they still take it....?? So realistically we are buying refurbished items lol, because they just fix up the old part that people send back
Old 08-14-2019, 04:08 PM   #4
Welker2
Welker2's Avatar
I would contact them and describe the damage to them to see; if its just a dent, my guess is they will take it.
Old 08-14-2019, 04:13 PM   #5
gtstorey
I just did a search on why they charge a core charge on plastic body pieces and it is to remove refurbished parts from availability. So they can sell more new pieces.
https://www.gm-trucks.com/forums/top...-core-charges/
Old 08-14-2019, 04:32 PM   #6
mr_honez
Wifey Lover
mr_honez's Avatar
Drives: 2013 Crystal Red 2LT/RS
Search around, you'll find it without a core charge. I got mine from Summit Racing a while ago without a core charge. I realize that mine is different but I'm sure you'll be able to find it somewhere
Edit- Summit has a core charge too
mr_honez is offline   Reply With Quote
Old 08-14-2019, 05:18 PM   #7
JLSuperfly
JLSuperfly's Avatar
Drives: 2014 Red Hot LS3
What if the fascia or lighting assembly is badly damaged?
Broken, damaged, or destroyed lighting assemblies are considered acceptable as cores as long as they are in the replacement part’s box. Broken, damaged, or destroyed fascias are considered acceptable as cores as long as they are labeled with the peel-away portion of the replacement part’s label.
JLSuperfly is offline   Reply With Quote
Old 08-14-2019, 05:25 PM   #8
camaro528
camaro528's Avatar
How much was your diffuser? Was fitment ok?
Old 08-14-2019, 05:26 PM   #9
camaro528
camaro528's Avatar
Thanks for sharing this!!
Old 08-15-2019, 05:39 AM   #10
camaro528
camaro528's Avatar
Can someone confirm that part#22829477 is the quad tip rear diffuser for a 2014 2015 Camaro for V8 and v6
Old 08-15-2019, 08:53 AM   #11
jokrz187
jokrz187's Avatar
Drives: 2015 1SS
I just checked on the following websites and they all state that it fit 14-15 V6 and V8:
https://www.gmpartsdirect.com/oem-pa...cover-22829477
https://www.gmpartsgiant.com/parts/g...-22829477.html
https://www.thatgmpartsguy.com/oem-p...cover-22829477
https://www.wholesalegmpartsonline.c.../22829477.html
Custom TSP Stage 2 Cam/GPI intake Ported Rod Mod /VARARAM CAI/Mishimoto Catch Can/1 LE front & rear sway bars/ engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill.
jokrz187 is offline   Reply With Quote
Old 08-15-2019, 09:11 AM   #12
mr_honez
Wifey Lover
mr_honez's Avatar
It fit perfect. It was a OEM diffuser
Old 08-15-2019, 02:51 PM   #13
camaro528
camaro528's Avatar
👍👍 thank ya!!
Old 08-15-2019, 02:52 PM   #14
camaro528
camaro528's Avatar
I'm curious how fast they can refund you back for the core charge once you send your old rear diffuser to them??
