Old 12-07-2019, 07:58 AM   #1
oldman14ss
Drives: 2014 1ss camaro
3:73 gears
anyone use these gears in a trutrac ? I'm seriously thinking of them as a mid point between 3:45 and 3:91 for my six speed 3:91 too steep for my tastes between first and second. thoughts? experiences? just need to raise the cruising gears a little and hole shot value. thanks the oldman.......
oldman14ss is offline   Reply With Quote
Old 12-07-2019, 01:24 PM   #2
Rich2010
Drives: 2010 Cyber Gray LS3 SS/RS
Just drove home with my new 3.91’s and although I didn’t hammer on it the car felt great. Now too low geared. The way it should have been from the factory. Still cruised at 2000 rpm at 75. My opinion, don’t waste the money only going to 3.73’s. 3.91’s or live with stock.
2010 Cyber Gray LS3-BTR stage 4-480/428 RXT and 3.91’s
Rich2010 is offline   Reply With Quote
Old 12-07-2019, 01:47 PM   #3
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
I agree with Rich2010. I have 3.91s and it feels normal. I can efficiently use 6th at freeway cruising speeds now too. Car should have came with them.
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 12-07-2019, 02:26 PM   #4
oldman14ss
understood thanks, the oldman...........
Old 12-07-2019, 02:29 PM   #5
oldman14ss
that's what I mean though, I want to cruise at 80-85 @ 2k rpm. also not have to jump from 1st to 2nd quickly. never did like leaving in 2nd also
Old 12-07-2019, 03:12 PM   #6
Rich2010
1st isn’t over that quick, you’ll still hit 47 in 1st and 69 in 2nd. I’ll attach a pick with your speed per gear with 3.91 and a 6500 red line.
Old 12-07-2019, 03:13 PM   #7
Rich2010
2200 rpm you’ll be doing 84 in 6th with 3.91’s
Old 12-07-2019, 05:59 PM   #8
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
My car has a decent cam and I start in first around 1500 rpm. Still has plenty to go. I daily drive it in traffic. I'm 100% positive you'd like the 3.91s
2014 2SS/RS LS3/M6
Old 12-07-2019, 06:00 PM   #9
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
in fact, doing a 3.73 would be a complete waste of money in my opinion. You probably wouldn't even notice a difference.
2014 2SS/RS LS3/M6
Old 12-07-2019, 06:26 PM   #10
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
they did come with 3.91's if you got the 1LE it would have been nice as a option for the SS .
lemontwist is offline   Reply With Quote
Old 12-07-2019, 06:30 PM   #11
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
1LE with 3.91 has almost the same final drive ratio as the SS because it has a different gear set in the transmission.
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
Old 12-08-2019, 09:36 AM   #12
oldman14ss
understood, I had found a web site that gave you speed and rpm for each gear when I built my forth gen the t56 for that year had the same gear ratio as the 5th gen 1le. if any one knows of a web site that offers that so a mathematically challenged old man can understand I would appreciate it . the oldman...........
Old 12-12-2019, 12:00 PM   #13
f5journal
Senior Camaro Fanatic
f5journal's Avatar
Drives: 2011 SS/RS manual - White
I put 3:91 in mine and love it
Former '68 and '69 Z/28 Owner...........Now sporting around in a 2011 RS/SS with........Kooks LT's and cats, JRE tune, CAI, scoop, ZL1 Bumper conversion, custom ZL-1 grille, halo harness, Painted silver stripes, GM GFX, black painted lower edge of skirts and rear bumper. MGW shifter.....and now a 3.91 1LE diff
f5journal is offline   Reply With Quote
Old 12-12-2019, 12:34 PM   #14
Mr2Hard2See
Instagram: Mr2Hard2See
Mr2Hard2See's Avatar
Drives: 2011 2SS/ RS
With your trutrac how often are you changing the gear oil?
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242
BTR dual springs pushrods lifters retainers etc
Che bronze trunnion Ls3 timing/valley cover
Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers
Mr2Hard2See is offline   Reply With Quote
