11-11-2021, 12:03 PM | #1 |
Drives: 2010 Camaro Join Date: Nov 2021
New starter motor not meshing properly
I’ve just installed a new starter to replace my sluggish old one. It starts the car but makes an awful grinding noise when doing so. Both the old and new starter look identical right down to the position of the gears.
I assumed installation was simple with just a couple of bolts and no shimming needed etc? https://youtube.com/shorts/1OBhJuZzPNI?feature=share |
11-11-2021, 12:13 PM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Sounds like shimming is needed.
11-11-2021, 12:13 PM | #3 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
If it’s the right starter you definitely need some shims. Not all starters seem to have the same molded dimensions.
11-11-2021, 12:29 PM | #4 |
Sorry for the dumb question, but how do I shim it?
11-11-2021, 12:41 PM | #5 |
Put spacers between the starter and block. You can look up starter shimming on youtube.
11-11-2021, 12:45 PM | #6 |
11-11-2021, 03:32 PM | #7 |
As I'm on the other side of the pond From you guys and I cant pop down the autoparts store and get shims for a camaro, I drew this up in cad based on my old starter and I'll get it cut in 0.3mm alu so I can stack a few if needed.
Am i doing this right? |
11-11-2021, 03:43 PM | #8 |
I'm not sure I would use aluminum, but it will probably work.
11-11-2021, 05:15 PM | #9 |
Looks pretty close. As I recall, the sides of the shims were straight. Slotted on on end for sure so you can slip them in w/out dropping both bolts.
Classic issue with GM starters going back decades. Due to differences in bell housings and starters the drive can be engaged in the ring gear too deep(no gear lash) causing the noise. Not sure of thickness. Maybe .015" or .020". Add as needed. Ditto gtstorey , steel would be better. |
11-12-2021, 05:35 AM | #10 | |
However, it just so happens my laser cutters doesn't have any ali that thin anyway so I'm going to have to use stainless. |
11-12-2021, 06:37 AM | #11 |
Drives: 2010 1SS Join Date: Aug 2015
Just a thought but what about getting another starter or brand? If you purchased locally explain to them the issue. That would be my first resolution but you can do the shim route if easier for you.
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
11-12-2021, 06:51 AM | #12 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Don't you have Amazon?
I used these on my truck with both the 6.0 and 7.0 engines. I changed flywheels a while back and no longer needed them. https://www.amazon.com/Dorman-02336-...C%2CB007QBSZ8U
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
11-12-2021, 10:51 AM | #13 | |
Same deal with the shims. I can buy legit ones, but they'll take a week to arrive and cost me $60+ once shipping and taxes are added, for just some little scraps of metal. |
