Old 03-29-2012, 09:29 PM   #15
Black Lightning
Black Lightning's Avatar
Drives: 2011 Camaro 2SS/RS
Originally Posted by blazzin1 View Post
The ONLY time I have ever used it is on the Interstate going about 70-75.
Same here.
Red hood spears; Corsa cat-back exhaust; Roto-fab intake; Engine bay black/red theme; Black outs including both bowties, tail lights, tail light bezels, and side lamps; gill stripes; 35% window tints; Side SS badges; Hurst-equipped badge.
Black Lightning is offline   Reply With Quote
Old 03-29-2012, 09:46 PM   #16
Mach
Mach's Avatar
Drives: White M6 1LT RS
Originally Posted by kencam View Post
Above 50mph in clear traffic.
Originally Posted by malave7567 View Post
I have a v6 m6 but this is what I do too. If i'm going over 50 and just cruising, I throw 6th. If i need to be adjusting speed to traffic, I stay in 5th at that speed.
Ditto... When 50 and above I got to 6th.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 03-29-2012, 09:47 PM   #17
IROCanSS
Drives: 89 IROC 350
Never
Just sent... don't want to offend anyone.
Old 03-29-2012, 09:59 PM   #18
Greggash
Greggash's Avatar
Drives: 2012 Silver Ice Metalic 1SS
I use 6th gear above 75mph
The car takes on a drone as soon as you put it in 6th.
But that is where the gas mileage is.
Greggash is offline   Reply With Quote
Old 03-29-2012, 10:07 PM   #19
jesserayjames
jesserayjames's Avatar
Drives: Drives a 2012 IOM 2SS/RS 6M
It's for Hi-way cruising............................
CAMARO 2SS/RS 6M
jesserayjames is offline   Reply With Quote
Old 03-29-2012, 10:18 PM   #20
stlrammer
stlrammer's Avatar
Drives: 2017 1SS Blue
I use it on highway when at steady speed above 60 MPH but good question.
stlrammer is offline   Reply With Quote
Old 03-30-2012, 01:06 AM   #21
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Originally Posted by OrangeVert View Post
All the time. I found it doesn't provide as high a ratio as one might think.
Originally Posted by ckaram View Post
35 or 40 seems way too low for 6th gear to me. I'm at least above 60 for my tastes and what feels right to the motor (able to smoothly accelerate, no bogging, etc.).
You guys must love wasting gas. I'm in 6th by about 40 mph.
SUX2BU is offline   Reply With Quote
Old 03-30-2012, 01:17 AM   #22
TinyToasta
TinyToasta's Avatar
Drives: way too fast....
w/o 6th I'd be in the single digit mpgs on the Autobahn. Above 150mph this thing drinks like a fish... and you still can have one heck of an educated conversion at this speed without screaming at each other
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive
Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73)
CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials
TinyToasta is offline   Reply With Quote
Old 03-30-2012, 05:27 AM   #23
swisscheese
swisscheese's Avatar
Drives: '91 Z28, '11 2SS L99
Poser....
But, yes. Most time over 55 is ok for 6th
everything below 50 seems very low
new: '11 Camaro SS, L99, black, io-interior
gone: '10 Camaro SS, LS3, black, iom-stripes, io-interior, custom-shifter, Hotchkis lowering springs, GMPP-mufflers, tinted windows, Vararam-ed and Jannetty-tuned, RX Catch Can
'91 Camaro Z28, 305TPI, black, iom-stripes, some goodies
swisscheese is offline   Reply With Quote
Old 03-30-2012, 07:16 AM   #24
Cincy10SSRS
Cincy10SSRS's Avatar
Drives: 2010 2SS RS M6
Glad you mentioned the drone. I have been "reminding" myself to put it in 6th more the last couple days when up to speed on the highway portion of my commute and I noticed the drone and was hoping it was normal.
For the few responders who say they use 6th in the city at 35-40, I just don't get that; seems way too slow for that gear. I can't imagine you'd have much of any pedal response but I could be wrong.
Cincy10SSRS is offline   Reply With Quote
Old 03-30-2012, 08:10 AM   #25
The Stig
knows 2 facts about ducks
The Stig's Avatar
Same. Once I hit 35 ish I go from 3rd to 6th
Click to view my build thread
Old 03-30-2012, 10:53 AM   #26
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
I don't do it for pedal response. I do it to save a little gas by using the least amount of power with the most amount of gearing advantage. Our cars have enough torque that you could idle in 6th gear and still be going 24 mph.
Obviously you won't have that neck snapping feeling when you mash the throttle, but that is just a wrist flip away in a lower gear.
Old 03-30-2012, 12:58 PM   #27
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
I use it whenever I feel like getting gas mileage.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 03-30-2012, 01:01 PM   #28
nytrorcr
nytrorcr's Avatar
Drives: I.P.C. 2SS vert, 21 wheels
Location: Cookeville, TN but Just above Atlanta, GA for now
When I had the coupe I never used 6th....except on long trips. I drive the vert in Sport all the time.
2011 2SS Convertible A6
nytrorcr is offline   Reply With Quote
