07-27-2012, 06:39 PM | #239 |
Drives: 2012 CAMARO ZL1 COUPE Join Date: May 2009
Anyone out there with the 2012 ZL1 doing any mods to increase preformance??
07-27-2012, 07:38 PM | #240 |
Drives: Camaro's, always have, always will. Join Date: Oct 2010
Well, although as much as we expected or would like to think, it is not pulling 11.xx's in stock form. The good news is the platform is so stout and sound that it does not require much to do so. And the canyon carving aspect is already in the bag. This car does maneuvering tricks that will astound you. The handling is so precise and sharp, it will blow your mind unless you drive road race courses on a regular basis.
07-31-2012, 05:19 PM | #241 |
Drives: 2001 camaro ss Join Date: Jul 2012
Why do you guys think the zl1 needs more power
07-31-2012, 05:30 PM | #242 |
Banned
Drives: 2010 Camaro 2SS/RS Join Date: Jul 2009
08-01-2012, 12:35 AM | #243 |
CaRaHoLiC
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp Join Date: Aug 2011
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me. |
08-01-2012, 05:23 AM | #244 |
Drives: 2013 ZL1 # 2195 Join Date: Jun 2009
I want to open up a can of WHOOP ASS on Mustangs!
08-01-2012, 09:06 AM | #245 |
Petro-sexual
More power is probably easier and cheaper. Less weight requires more exotic materials, because I really don't think GM is going to remove ammenities, and they sure as heck aren't going to remove A/C, heater, or anything crash-related. Adding more power is probably the best bet (if any at all). My problem is, if I were thinking it's as easy as an LS9 cam, and maybe blower, it takes more to support those parts for similar power. There's a reason GM wanted Ti valves and rods - they wanted to rev' to 6500, and felt it was necessary to control the valvetrain better with less weight. Anyways - I think the fastest and maybe least expensive way would be the 2300 and a cam with more lift; Heck - maybe just a bit bigger cam and add a little more boost to get it back to 9-psi with the cam.
Whatever the case, I'm more confident the TR6060 will handle the extra power (and maybe extra RPM-range if there is a different cam), and think the rest of the driveline would be up to it. How could a 9.9" diff' not, lol? I think GM SHOULD make any efforts to improve the power they can. I really don't think they can ignore that ZL1 could use it. It's one think to be a tenth away at the strip - the situation now, is quite different. However - it's opposite around a track, but there have been great times by the Imp, too. Chassis-wise - I couldn't ask for more. I propose an Z07-style package for ZL1, like Z06 has: 2300 or a few more psi from the 1900 (I just think jumping to the 2300 would introduce less heat than adding more boost from the 1900), and maybe more aggressive springs and stab' bars. Better yet - consider it a 1LE-package for ZL1 I'm not up-to-speed in this thread, so if this is a repost, I'm sorry :( JMVHO.
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
08-01-2012, 09:12 AM | #246 | |
Drives: '19 ZR1 Shadow Gray & '16 Z06 LBR Join Date: Jul 2010
08-01-2012, 10:51 AM | #247 |
Drives: 2001 SS, Slp Join Date: Feb 2012
Weight down, Hp up.
Then there is getting to the ground! |
08-20-2012, 08:55 AM | #248 |
Drives: 2013 ZL1 Join Date: Aug 2012
Hey guys. Thinking about buying a 2013 ZL1. Should I wait for 2014 ?? Horsepower boost coming ??
08-20-2012, 08:59 AM | #249 | |
Drives: Cadillac on four flats Join Date: Mar 2012
