03-20-2015, 07:57 PM | #1 |
Procharger f1x shredding cog belt
installed The procharger f1x we are running approximately 1,000hp. After talking to the procharger rep the stock bracket is not capable of supporting that much horsepower. Does anyone sell a prefabricated solution to support this belt shredding from happening? This is a smaller cog pulley we are making around 20lbs of boost. Any advice would be greatly appreciated!
03-20-2015, 08:53 PM | #2 |
03-20-2015, 11:03 PM | #3 |
Really, Really Fast
Drives: 2010 Camaro SS Join Date: Feb 2013
That car is familiar
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
03-20-2015, 11:04 PM | #4 |
Really, Really Fast
Follow the link in the thread. Buy the pulley from ati. It will solve your problem
03-21-2015, 09:28 AM | #5 |
Drives: 2011 Synergy Green 1xxxrwhp Join Date: Sep 2012
that bracket i built is what solved the problem for that F1X ryan, i was shredding belts even with the ATI Super Pulley, hence the reason i made gaurd and bracket
03-21-2015, 09:32 AM | #6 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
You can add a strut,it will work and be much cheaper than a bracket. If you need some help with it give me. Call
03-21-2015, 09:55 AM | #7 |
Drives: Camaro SS Join Date: Jan 2013
I thought the new bracket they make was supposed to solve this issue.
03-21-2015, 05:38 PM | #8 |
I have the upgraded ATI, that didn't work. Do you have a pic of this strut?
03-22-2015, 08:33 AM | #9 |
Really, Really Fast
Well I guess the guard is working without the brace. Because I never hooked it up. Even on stock motor mounts
4k miles. Still on the same belt. Works great
05-08-2015, 12:51 PM | #10 |
Annihilator
Drives: 2012 45th ERL-427 F1X Join Date: Aug 2011
Can you please tell me what belt you have and do you have the new mounting plate with the added idler pulley.
ERL M3 Superdeck 427 Forged, Dragon Slayer Crank, Black Label Heads : ProCharger F1X Cog - Holley HighRam : Jakes4L80e CircleD - DSS 9" 1400 axles/shaft, BMR Suspension : Extreme Innovations 15 : Squash, Bosch 127lb FI : ALKY Twin Meth
06-18-2015, 10:01 PM | #11 |
Annihilator
? - how have thing s been holding up and are u using the new plate, new belt, and new idler - and is it holdlng up well dip for you. Very curious. My thanks. Chris
