Old 03-26-2015, 11:26 AM   #1
tlau2010ss2
Drives: 2010 SS2 Camaro
Question Gurgle/Fluid like sound from the passenger side
2010 SS2- Has anyone noticed a gurgle/fluid like sound from the passenger side when accelerating past 2,000 RPM? You would have to listen for it with the radio low to hear it, but on some occasions the sound isn't present. With research I have been trying to find, I found out that it could be a valve on the heater core. I tried driving it with the radio off, the heater off, and the a/c on, but the sound is still present. I took it into the dealer and the service manager heard the sound and brushed it off as a normal non-threatening issue. However with the past experiences I have read in other forums, I can't take full trust into what they said. So far the sound hasn't resonated louder, or happen at a constant, just when I accelerate past 2,000RPM. I can't say that it is getter worse, but any info. or previous threads regarding this noise would be greatly appreciated.
tlau2010ss2 is offline   Reply With Quote
Old 03-26-2015, 12:30 PM   #2
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Yeah, definitely sounds like heater core area and as the dealer said may not be a big deal. The good thing is you have it documented with them in case it gets worse or an issue pops up.
Old 03-26-2015, 12:54 PM   #3
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Just the day before yesterday, I was driving my truck and it started running hot. To make a long story short, the damn thing had hardly any water in the radiator. After topping it off I had that same sound for about five min after starting it up. It was an air pocket and after a while the sound went away, I topped off again and no issues since. Check your fluid lately?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 03-26-2015, 01:21 PM   #4
tlau2010ss2
I have been keeping up on the fluids and I do have an appointment for an oil change on Sunday. I will see if they could possibly bleed the lines to rule out any air in the lines.
Old 03-26-2015, 02:38 PM   #5
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Coolant doesn't just disappear. Did you check for a head gasket leak? Or a is your heater core leaking?
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 03-26-2015, 03:04 PM   #6
tlau2010ss2
No leaks, levels are fine. Or was that a question to the previous post with the truck?
Old 03-27-2015, 09:30 PM   #7
OUTATIME
OUTATIME's Avatar
Drives: 2010 IOM 2SS/RS
There was a TSB for that gurgle - I had that fixed. I can't remember the details. Search and I'm sure you'll find a lot. I think it was the AC condenser line or something like that behind the glove box.
OUTATIME is offline   Reply With Quote
Old 03-28-2015, 09:38 AM   #8
Fast1
Fast1's Avatar
Drives: 2010 Summit White SS
Same here. I took mine for the tsb and seems like the tech did something with the line. I don't quite remember.
Fast1 is offline   Reply With Quote
Old 04-02-2015, 09:09 AM   #9
tlau2010ss2
I currently have my car in for a brake down from a different problem, any information regarding to which TSB would be greatly appreciated so it could get fixed at the same time
Old 04-03-2015, 07:33 PM   #10
OUTATIME
OUTATIME's Avatar
Try this one: http://www.camaro5.com/forums/showthread.php?t=46740
