07-31-2018, 08:39 AM | #1 |
Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
brake cooling duct screws
Does anyone have a trick to get the screws out of the aluminum arms without the heads snapping off?
I haven't done mine yet but when I did my swaybar a while back the instructions told me to remove those ducts. I did two screws and the heads snapped off so i stopped and managed to do the sway bar without taking those off. But now I have a track day coming up and need to but the larger brake ducts on. Oh and put the OE ones back on after the event! So Does anyone have any tricks? Id rather not have to drill them out again lol.
#53 F Street
2022 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 2022 Rapid Blue 1SS 1LE 2019 D Street national champion (2019 civic Type R) |
07-31-2018, 09:18 AM | #2 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Hmm, never had that issue with them on the cars I’ve messed with. How far into the bolt hole did the bolt snap off? Picture?
07-31-2018, 09:22 AM | #3 | |
It snapped right in the arm, just the head came off. And i did this when the car had only 1000 miles on it a year and a half ago lol. I think its a problem with the type of screw in the aluminum. If it happens again when i try it next week ill post a photo.
#53 F Street
07-31-2018, 11:05 AM | #4 |
Drives: 2016 1ss camaro Join Date: Feb 2016
never had that issue and i put mine on last year before my first track day and just left em on lol no ragrets
07-31-2018, 11:38 AM | #5 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
This will be a bit anticlimactic, but my dealer had accidentally installed the track deflectors prior to delivery, and then also snapped off one of the bolt heads when asked to restore the street setup. I looked at it and it was not easily fixable, so they offered to order and install a new lower control arm for me, which went without a hitch.
There didn't seem to be any other way, I doubt even drilling the bolt out and rethreading the hole could've worked, because the bolt is steel (not even brass) and the control arm is aluminum, and I didn't want a larger diameter hack.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
07-31-2018, 12:37 PM | #6 | |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
I'd probably try the pentrating lube first. If you do try using heat be careful not to get the arm too hot or it could create a weak spot in the arm. It's probably heat treated/hardened aluminum and heating it up too hot and letting it air cool could reverse the heat treating process and therefore lower the strength of the arm at that point.
08-01-2018, 09:14 AM | #7 |
The bolts are small diameter, we’re dealing with aluminium and if the bolts are snapping off, they likely wont be extractable easy...
If there is a bit of a head sticking out above the bolt holes boss, above the surface, it’s worth a shot. Otherwise, don’t waste your time. Zip tie the deflectors and replace the control arm later. Probably not what you want to hear, but the reality. If you are going to try to extract, soak the broken bolts in brake fluid. Brake fluid is an effective penetrant that won’t harm the aluminium. Heat the control arm, not the stuck bolt, with a heat gun (no flame, that’s too hot and can impregnate the aluminium, change the comp. and weaken the arm). Than either use a vice-grip plier to twist the bolt out or welda nut or bolt onto the broken bolt. |
Thread Tools | |
