01-19-2019, 01:34 PM | #1 |
Drives: 2013 camaro zl1 aka the Reaper Join Date: Apr 2018
bad vibration in the rain
so i have a really bad vibration in my car when im driving in the rain. it only happens when its raining. it gets so bad at times that it shakes the center console. it does it while im at a dead stop as well. ive crawled under the car and checked everything i thought it could be but still nothing, ive asked friends and chevy cant reproduce the issue so it "doesnt exist" anyone have this issue before or have any ideas what it could be?
01-20-2019, 11:44 AM | #2 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
If it's exactly as you describe it I'd look for a plug wire that gets shorted when it's wet. Might take a water mist bottle and spray the coils and wires one at a time and see if a misfire starts on a dry day. Silicon spray sometimes can waterpoof wires but if it already has some insulation rub through it needs to be moved and or replaced.
01-20-2019, 02:17 PM | #3 | |
i thought so to but it drives perfectly fine even while its vibrating. i did check it though |
01-20-2019, 02:43 PM | #4 | |
01-20-2019, 05:51 PM | #5 |
01-20-2019, 06:10 PM | #6 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Move.
01-20-2019, 06:28 PM | #7 | |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
01-20-2019, 06:53 PM | #8 |
Drives: 2013 Camaro SS Join Date: Apr 2017
I have 100% had this same problem. Only happens in the rain when my drivers side tire hits a puddle. I have narrowed it down to possibly being the large amount of water landing on top of the header collector on my long tubes and rapidly boiling and popping and hitting the heat shield. It becomes quite violent
2013 SS M6, TSP Stage 3 231/246 cam kit, TSP Trunion upgrade, Cold Air Inductions CAI, VMAX PTB, TSP 1 7/8 Long tube headers and high flow cats, Corsa Xtreme ZL1 Catback exhaust, Elite E2-X Catch can, Trick Flow Gen-X 255 heads milled 0.025 and valve job, GPI rod mod and ported intake, ID850 injectors,ZL1 fuel pump, Flex sensor and E-85, Mantic 9000 and 1LE 3.91 diff 512rwhp/462rwtq
01-20-2019, 06:57 PM | #9 | |
01-21-2019, 09:16 AM | #10 |
Drives: 2015 SW 2SS 1LE Join Date: Jan 2018
I have a friend that drove his '12ss here from Houston last Wednesday and had the same issue. He said it was pretty scary 75mph.
Maggie 2650 @ 18psi/ 75mm 10 rib/ Dual alky nozzles/ Roto-fab/ ARH 2" Lt's/ GT-12 cam/ ZL1 3.23 Conv./MGW/RPS triple carbon clutch/RSG tranny upgrage/Pedders Ex. XA w/ remote cans and a lot of other crap 897/8??@tires
01-21-2019, 12:21 PM | #11 |
Drives: 2014 RRM ZL1 Join Date: Apr 2014
Bring it to the Dealer on a rainy day and take them for a ride to reproduce.
01-21-2019, 01:26 PM | #12 |
01-21-2019, 01:31 PM | #13 |
01-21-2019, 02:49 PM | #14 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Do you still feel the vibration if you push the clutch in ?
