Old 09-05-2011, 08:22 PM   #1
Oxtar41
Oxtar41's Avatar
Drives: 700 rwhp 2010 SS
My Forged 418 Stroker Build (Have a few questions)
So I decided to make a list of the stuff I'm going to need in order to "bullet proof" my ride. Ill give you a little info on my goals and a few of my questions and if anyone thinks its overkill or something else is needed please let me know.
Info about my car how it sits now:
Currently running about 7.5lbs with a E-force.
Dynatech Long tubes
MSD Boost pump
Roto-fab CAI
JRE fuel system upgrade
RX catch can
Jannetty Tuned
Makes 546 HP and 523 ft/lbs at the wheels
Goals:
1. Must be streetable, The car will be my DD for the most part during the summer.
2. I want atleast 700 RWHP
3. Want it to be able to run on 93 pump gas
Questions:
1. Does the block need to be bored or is it just a diff stroke to make a 418 using the ls3 block.
2. I'm using my block (18k miles, 6k miles being supercharged) Is there anything I need to do or you would suggest before using it as the platform for my current build. Like strength tests etc?
3. I plan on using the stock heads but having them cleaned up a bit, Is this recommended or just a waste of money?
4. Anything else I need? Diff oil pump?
Heres the list, Input is much appreciated I have a budget of 12k and rounded the numbers up to make it easy. I will be doing ALL of the work myself. This is for parts alone.
My 418 Stroker Build.
Rotating Assembly: JRE 418 LS3 Forged Stroker Rotating Assembly
Price $2300.00
Cam / Valvetrain: JRE LS3 Rough Idle Hot Street Blower Cam Package Price $1400.00
Clutch: LS9X Clutch for 2010+ Camaro Price $1600.00
Axles: 2010 Camaro SS Driveshaft Shop Level 5 Rear Axles Price $1500.00
Injectors: ID850's Price $960.00
Fuel Pump: ADM Dual Pump Price $1400.00
Driveshaft: Dss Driveshaft Price $900.00
Rear End: JRE Posi Mod Price $200.00
Susension: Pfadt Camaro Drag Racing Kit - Stage 1 Price $1700.00
Supercharger Pully: E-force 3.00 Inch Price $39.00
Oil Pump: Price $
Bore Cost: Price $
Head Work: Price $
Studs: ARP Headbolts Price $295.00
Gaskets: Head Gaskets Price $40.00
Oil / Filter: Mobil 1 Price $80.00
Total so far:------------------$10,644.00
Oxtar41 is offline   Reply With Quote
Old 09-05-2011, 08:45 PM   #2
tsears
tsears's Avatar
Drives: 2010 Camaro 2SS/RS - L99 - CGM
I'm going through the same situation. 416ci - twins. Looks like you've got a good plan so far... good luck
2007 Corvette Z06 - Velocity Yellow
Halltech | Forgestar | Bilstein
tsears is offline   Reply With Quote
Old 09-05-2011, 08:47 PM   #3
Oxtar41
Oxtar41's Avatar
Thanks! I cant wait for the winter so I can rip this pig apart lol
Old 09-05-2011, 08:54 PM   #4
tsears
tsears's Avatar
Lol, I would try and do some of the work myself, but I don't have the space in the garage. I like what you've got setup. But how come you didn't go with the 416 over the 418?
Old 09-05-2011, 09:15 PM   #5
Oxtar41
Oxtar41's Avatar
mostly because I will be getting all my stuff, if not everything from ted jannetty. He has a nice set up for the 418. And 2 more cubes = me picking on 416's for being 2 cubes smaller lmao! J/k.
Old 09-05-2011, 09:35 PM   #6
mike25
mike25's Avatar
Drives: 2012 Camaro 2SS/RS
or they could go 427 and pick on you
2LT/RS M6 CGM VIN#53104 SOLD
2012 Black 2SS/RS w/ Hurst-
Mods:
Corsa catback, SSE, Vararam
mike25 is offline   Reply With Quote
Old 09-05-2011, 09:45 PM   #7
Oxtar41
Oxtar41's Avatar
Lol, something like that
Old 09-05-2011, 09:54 PM   #8
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Looks good im about to go with 416. Can you elaborate on the 200 posi mod how is it that cheap?
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 09-05-2011, 09:59 PM   #9
Oxtar41
Oxtar41's Avatar
Its ted's posi mod. it just makes it so you dont have 1 wheel burnouts when you have high hp from what i understand.
Old 09-05-2011, 10:43 PM   #10
tsears
tsears's Avatar
Damn those ID850s are expensive. Did you have any other options when considering injectors or fuel system?
Old 09-05-2011, 10:54 PM   #11
Busy_Boi
SoCal C5 Family Member
Busy_Boi's Avatar
Drives: RJT 2010 camaro 2SS
Send a message via Yahoo to Busy_Boi
I think you should use a 2.75 pulley with your set up it should put you at 9lb of boost with the E-force and put you right at your goal.
Busy_Boi is offline   Reply With Quote
Old 09-05-2011, 11:49 PM   #12
Oxtar41
Oxtar41's Avatar
Ted yells at me everytime I talk about diff injectors lol. Read up on the id850s its good stuff!
Old 09-05-2011, 11:51 PM   #13
jrpxxii
jrpxxii's Avatar
+1 that is very expensive for injectors
Old 09-05-2011, 11:59 PM   #14
tsears
tsears's Avatar
What are you running jr?
V6 Questions I'd Like Answered The_Blur Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 36 07-14-2012 10:44 AM
Late model year build and questions... blake-b Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 0 05-22-2010 02:49 PM
pics of my 442ci LS7 forged stroker install in progress mark_p Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 24 03-18-2010 10:20 AM
402 Stroker LS3 with FI? 91Z28350 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 06-13-2009 01:39 AM
