07-24-2014, 05:50 PM | #1 |
zl1 clutch vs ss clutch
I will be getting a zl1 soon. How does the clutch compare to a 2012 ss? Is it the same or have a heavier feel? The 2014 gt500 clutch I did not like. Also when you step out of the ss and into the zl1 and drive it for the first time. How much different does it feel?
07-24-2014, 07:59 PM | #2 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
07-24-2014, 10:59 PM | #3 |
07-25-2014, 01:41 AM | #4 | |
Drives: 2014 Black ZL1 Join Date: Jan 2012
It's heavier. In my experience between my 2011 ss and a 2014 1le it's a bit crisper. I prefer a heavier clutch pedal but it's not taxing at all.
2011 2SS, 535 rwhp (sold)
2013 300 SRT8 (sold) 1968 Triumph T100C 1960 Ford thunderbird 390 FE 2014 Camaro ZL1 |
07-25-2014, 08:23 AM | #5 |
ace5.org (Atlanta Club)
Drives: 2010 Black/IOM 2SS LS3 Join Date: Sep 2013
Go test drive one. I couldn't feel much difference between my 2010 SS and the ZL1. Pedal firmness and release point are pretty much the same.
07-25-2014, 07:53 PM | #6 |
Any other opinions?
07-25-2014, 08:02 PM | #7 |
Ragtop Rocket!!!
Drives: Black on Black Convertible Join Date: Mar 2013
As far as the driving experience. There is no comparison!
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package. 744rwhp 727rwtq |
07-26-2014, 01:30 AM | #8 |
Drives: 69 Chevelle SS396 2013 ZL1 Join Date: Mar 2010
ZL1 pedal only needs to be depressed half way to shift on my car. It makes shifting that much faster.
07-26-2014, 01:39 AM | #9 |
Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
My SS is that way
2011 2SS/RS built 8/24/10
07-26-2014, 08:15 PM | #10 |
Thanks for the info.
07-26-2014, 08:46 PM | #11 |
Drives: 2014 ZL1 White Convertible Join Date: Aug 2013
pressing the clutch in 0nly half way sounds risky... if you are off then you will be grinding those gears away.
