10-07-2015, 07:41 PM | #1 |
Drives: 2015_1le Join Date: Apr 2014
Rear Diff and Engine Oil change
Hey guys. Will be doing a rear Diff and oil change on a 15 LS3. Just wondering if anyone knows the torque śpecs for either. As well, assuming I don't have a torque wrench, what is the best way to estimate it?
10-07-2015, 08:37 PM | #2 |
Drives: cars Join Date: May 2011
You don't estimate a torque wrench setting, you buy a torque wrench.
10-07-2015, 08:48 PM | #3 |
10-08-2015, 09:59 AM | #4 |
It is, you're just unwilling to receive it.
10-08-2015, 10:03 AM | #5 |
10-08-2015, 10:04 AM | #6 |
10-08-2015, 10:04 AM | #7 |
No...
10-08-2015, 11:15 AM | #8 |
Scenic City Camaro
Drives: 2022 Camaro ZL-1 /1974 Firebird 400 Join Date: Jan 2014
I have always laughed at people who use their arm as a torque wrench. But the 2 bolts in question hardly need one.
CRF: Sent from my iPhone using Tapatalk
2022 Camaro ZL-1, grey
1974 Firebird Formula 400, white https://www.facebook.com/groups/Camaro/ https://www.facebook.com/CRFinTN/?modal=admin_todo_tour |
10-08-2015, 05:40 PM | #9 |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
Rear diff drain and fill plug 24 lb ft
Oil pan drain plug 18lb ft You can estimate the oil pan plug by ensuring the wrench is covered in oil and grab it between your thumb and fore finger and push (not pull) till you slip off the wrench and bust your knuckle. If your a little older you may need to use thumb and 2 fingers (maybe 3) The diff is just a wee bit more force than the oil plug. ***Note*** these are for Mobil 1 full synthetic being on the wrench, DEXOS blends may not slip the same resulting in the knuckle being spared from being busted open. See how this sounds? If you are going to start doing DIYs like this just buy a torque wrench. |
10-08-2015, 05:59 PM | #10 | |
Thank you. |
10-06-2016, 03:31 PM | #11 |
Drives: Z/28 Join Date: Jan 2015
I think the bottom line here is that if you want to do the job correctly the only way to do it is with a torque wrench. There is no "trick" to approximating a torque spec, nor would anyone who works on cars expect there to be.
Just invest in a torque wrench. Here's a cheap one for you: https://www.amazon.com/TEKTON-24330-...=torque+wrench |
10-06-2016, 04:19 PM | #12 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
These 2 bolts don't require a torque wrench. I never torque those bolts to spec.
Hand tight (plus a touch) only, don't use your arm as leverage on the ratchet. Always start the car and check for leaks after. However, do invest in a proper torque wrench if you are rotating your own tires or doing work on the engine.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
10-06-2016, 04:38 PM | #13 |
Instagram: Sangstah
Yup I just tighten those two bolts down snug, but not overtightened, no need for a torque wrench.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
10-31-2016, 12:07 AM | #14 |
I apologize for my fellow canadian"s remarks .
Buy a damm torque wrench, my .02 !! |
