01-20-2018, 04:50 PM | #1 |
Drives: 2014 ZL1 Join Date: Mar 2014
It just cut out while I was driving.
Ignition switch took a shit while I was driving. Pulled over turned the key a few times and no juice to the pumps.. 😠😠 all lights in the cabin are functional except no power going to my gauges. Wait a few minutes and gauges are working and you can hear the pumps. Seems to be an intermittent problem. Suggestions and input is definitely welcomed.
822rwhp and counting...
01-20-2018, 04:52 PM | #2 |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
What "pumps"? Fuel?
01-20-2018, 05:12 PM | #3 |
Yeah.. My gauges lost power but everything else in the cab was working. Pulled over tried to start it a few times and the pumps aren't turning on. Waited a few minutes and had power to the gauges. I was happy to be home in one piece.
01-20-2018, 05:40 PM | #4 |
I think you're in the right realm: electrical.
I would check battery terminals, fuses, ignition switch and relay in that order. |
01-20-2018, 05:50 PM | #5 |
I appreciate the response bud, it just sucked how it happened and could've been worse if I crashed.
01-20-2018, 06:10 PM | #6 |
You're welcome. Yeah, but better cutting off than taking off like a rocket. At least you got home safely. I just wouldn't take it out again until fully diagnosed and repaired.
Let us know the results. |
01-20-2018, 06:26 PM | #7 |
You're right on.. if I can't figure it out I'll trailer it to my speed shop. I'll check back.
01-21-2018, 11:54 PM | #8 |
Drives: 2013 Camaro ZL1 Join Date: Oct 2012
I had a similar problem a few years ago. Turned out to be a wire connected to fuse box in the front right. When I'd accelerate, the engine would torque and pull on the wire causing the power to die out. Gauges and engine would die out for few seconds and come back.
01-22-2018, 01:46 PM | #9 |
Drives: 2015 ZL1 Join Date: Jan 2018
If it's the original battery, it could be going bad. I've had them seem 100% fine and then all of a sudden fail to start. I had one that lost all power, no lights or anything. When I went to wiggle the positive battery post to check the contact, it broke off the battery.
