04-17-2021, 06:23 PM | #1 |
Drives: 15 Camaro SS Join Date: Oct 2018
Venting blow off valve to atmosphere
So installing me ESS system and curious if i can just allow the blow off valve to vent to the atmosphere instead of routing back into the suction side?
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
04-17-2021, 09:51 PM | #2 |
Drives: 2009 ZR1 Join Date: May 2010
Yes, you can.
04-18-2021, 06:45 AM | #3 |
Thank you
04-20-2021, 05:31 AM | #4 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Yes, I just put a rubber cap with a hose clamp on the intake filter piping. It will only see vacuum.
If you decide to turn that sucker up to the point where you need more surge valve, you can get one of these... http://www.siliconeintakes.com/bov/t...waAk1UEALw_wcB and connect a Tial 50mm Surge valve to it. (2 psi spring) I cut out the section of 3 inch silicon hose where the Vortech bypass valve goes, and t bolt clamped this in place. Then I also welded another 50mm onto the intercooler. [credit goes to Big Biscuits for that idea] Good luck man. I'm really excited to see the G2. I think its gonna be a torquey SOB with your current H/C combo.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
04-20-2021, 11:23 AM | #5 | |
04-20-2021, 12:50 PM | #6 |
Nice, they didn't have that option when I bought mine.
Oh my bad on the blower. Thought I read somewhere you went G2. G4 bracket isn't ready for the camaro yet, but it should be soon. G3X is a nice fit for a 376. I could see your combo making 700+ with the V3. Good luck.
04-20-2021, 08:08 PM | #7 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
The BOV sound is contagious.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
04-20-2021, 08:46 PM | #8 | |
04-20-2021, 08:46 PM | #9 |
04-24-2021, 12:22 PM | #10 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
I run two on my YSi set up. A tial 50mm set at 2psi and a vortech race valve. I loved the sound of them opening between shifts.
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
