04-17-2014, 03:30 PM | #1 | ||
The Beast
Drives: 13 2SS/1LE/RS/NPP/NAV/SUNROOF Join Date: Apr 2013
HELLPP!!! Just did cam and heads....
Well I tried to crank it up and its very hard to start and when it does( with a little throttle if you hit the gas it will back fire...it will run kinda rough at 1200rpms but if you let off it will die...
....timing marks are lined up... Video of it running from exhaust *EDIT* From Valve cover UPDATE!!! Well got it checked out and it looks like the coil harness was backwards, or swapped idk....The squeaking is the header gaskets..they say($200) for diag and replace gaskets. I told them to go ahead...But they said it runs on its own now.... Will update with a new video when I pick up the car
N.F CAM, P&P HEADS, SLP UDP, C.A.I., TRI Y'S, BMR 1" SPRINGS & SWAYS, PFADT TIE RODS & TRAILING ARMS, TUNED BY MATT@FSP 490HP/428TQ
04-17-2014, 03:33 PM | #2 |
The Beast
I cant get any codes to pull....does it have to run for a while???
*edit* I got it to run long enough for the thermo to open...still no codes...
04-17-2014, 03:59 PM | #3 |
502 RWHP N/A
What size cam
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
04-17-2014, 04:17 PM | #4 |
The Beast
This is what I just did...
Night furry Cam 233/242 113lsa Gtp P&P heads Ls9 Head Gaskets ARP head/ cam/ balancer bolts BTR Spring kit platinum w/titanium retainers BTR 7.425 pushrods BBK fuel rails Flipped Fuel rail Corvette fuel line Holley Valve covers Rerouted EVAP hoses IWIS timing chain Melling high volume/std pressure oil pump Slp udp
04-17-2014, 04:28 PM | #5 |
Geek
Did you check PTV clearance? How much were the heads milled?
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
04-17-2014, 04:29 PM | #6 |
The Beast
Did not check....did not mill only p&p
Sent from my HTC One using Tapatalk
04-17-2014, 04:34 PM | #7 |
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
You didn't change the injectors did you? Are you 100% positive the marks lined up properly? Coil packs hooked back up on both sides?
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
04-17-2014, 04:36 PM | #8 |
The Beast
I moved around the injectors for new rail...but stock injectors
04-17-2014, 04:38 PM | #9 |
The Beast
I rechecked codes...p0300....dreaded random missfire
04-17-2014, 04:40 PM | #10 |
Drives: 2009 ZR1 Join Date: May 2010
Double check that your wires are on the plugs and coils tightly. It is very common after taking them off for people to experience misfires because they weren't put back on all the way.
I believe you will feel one click when going on the plug and two "clicks" when going onto the coils. |
04-17-2014, 04:56 PM | #11 |
The Beast
Wires are ok......why does this say 32* advanced.....The cam mark are lined properly, right???
04-17-2014, 05:23 PM | #12 |
If you are still running the stock tune, that is most likely the issue. When I changed my cam (the first time) and was on the stock tune, I remember it acting like yours does.
04-17-2014, 05:28 PM | #13 |
Drives: black on black 2SS/RS Join Date: Feb 2010
if you put an aftermarket cam in your car you will need a tune for it to act right
04-17-2014, 05:44 PM | #14 |
The Beast
I have been tuned but on stock cam....Mike @ fast automotive said I may have got the cam 180* off.....will that cause me to bend valves?
