Old 08-11-2016, 10:37 AM   #1
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Track day oil temp?
Just curious what others have seen during their track day when it comes to your oil temps?
Mods:
Old 08-11-2016, 12:02 PM   #2
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
Non track I've seen mine hit 270 to 280 with some spirited driving so I would imagine you could easily hit over 300.
jayno20 is offline   Reply With Quote
Old 08-11-2016, 01:23 PM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
in my ZL1 the oil temp would frequently get as high as 310 degrees. In the Z/28, it can hit 305 degrees by the end of a session. The oil temp quickly subsides after the end of a session thank goodness.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 08-11-2016, 07:01 PM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Ok, just making sure. lol
I looked down at the temp gauge while at Buttonwillow last week and almost had a heart attack....
Mods:
Old 08-11-2016, 07:47 PM   #5
L99CAMA2011
L99CAMA2011's Avatar
What weight oil.
Old 08-11-2016, 09:44 PM   #6
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
I was running at thunderhill and instructor I was with was like your oil temp is over 300... Eh whatever ... Ran a 1/2 cool down lap then back at it... Running Amsoil 5-30 then ... Going to 10-40 next day
Crash76 is offline   Reply With Quote
Old 08-11-2016, 10:11 PM   #7
E. Bryant
Gearhead
E. Bryant's Avatar
Drives: 2012 ZL1
Per the gauge, mine runs over 300F on a 85-90F day. I'm running Mobil 1 0W40.
Note, however, that my gauge reads higher than the actual value per my DashLogic (it's off by about 10-15F).
2012 Chevrolet Camaro ZL1 M6 - JRE 650 RWHP kit, AFCO heat exchanger, JPSS V4 aero, Z28 wheels for the twisties and Weld big-n-littles for the dragstrip.
11.193@128.13 in 515' DA
E. Bryant is offline   Reply With Quote
Old 08-12-2016, 07:48 AM   #8
z28lt1
Drives: 2014 ZL1
Note that the Oil Temps are estimated by computer algorithm. I've never been able to reconcile while the gauge and the obdii readings are not the same, but they are not, and sometimes one is higher than the other, but both are not true temperatures.
Someone here previously posted a grassroots motorsports article where they installed an actual temp sensor in the pan on an SS and found that track temps on the gauge were getting close to 320, but in the pan were really only 275-285, so take the gauge estimates with a grain of salt.
z28lt1 is offline   Reply With Quote
Old 08-12-2016, 08:51 AM   #9
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Ok, well good to know. Thanks for the reply's.
Mods:
Old 08-12-2016, 09:03 AM   #10
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
295-300 on a 85 degree day after 7 laps at Watkins Glen.
Edit: The first high oil temp message you get is "AC has been disabled due to high engine temp" Note that I do NOT track with the AC on LOL it just displays that message. Second message you get is something like:"high engine temperature, allow to cool before shutdown"
I'm paraphrasing on both since it's tough to read that little display on a track full of cars doing 100mph
Thor142 is offline   Reply With Quote
Old 08-12-2016, 09:15 AM   #11
Thor142
Thor142's Avatar
Just wondering can you feel your car pulling timing / losing power at high temps? I have heard the ZL1 does that.
Old 08-12-2016, 10:15 AM   #12
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
We highly recommend installing an oil cooler.
Old 08-12-2016, 10:49 AM   #13
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
This is what happened to me...I looked down because I know I didn't have the A/C on. lol
I can feel it. The car just isn't a quick off the corners when this heat soak happens.
Ok cool. Which one?
I know the ZL1 has a OEM oil cooler already. Where would you put another one? An would doing so drop the oil pressure to dangerous levels?
Mods:
Old 08-12-2016, 11:01 AM   #14
Thor142
Thor142's Avatar
HAHAHA!!! I was like WTF?? Did I leave the A/C on after I got gas WTH is going on?
