08-18-2017, 04:31 PM | #1 |
Drives: 2014 Camaro ZL1 Join Date: Jan 2015
trunk does not open when i press the button on the drivers door?
What could it be? Bad switch or fuse. The button on remote still works.
08-18-2017, 06:14 PM | #2 |
Drives: '23 LT1 A10 Join Date: Oct 2015
If the doors are locked and you press the button it will not work. Maybe this is the case. If not sounds like a bad switch.
24 LT1 M6 Sharkskin Metallic
08-18-2017, 08:23 PM | #3 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
M6 car? The E-brake needs to be on.
Bryan 2018 ZL1 M6
08-19-2017, 09:05 PM | #4 |
Drives: 2014 Red Hot ZL1 Vert. M6. Join Date: Jan 2014
08-19-2017, 09:20 PM | #5 |
KaBoom1701
If the remote work the trunk I would say it's a fuse or wiring issue.
Mods:
08-20-2017, 09:25 AM | #6 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
08-21-2017, 01:18 AM | #7 |
K thanks guys for your input. I tried popping the trunk with the key to the run position and it still did not open. So I started the car and pressed the button twice and it opened. I closed the trunk turned the car off and popped the trunk open. now it works just fine. I do not drive the car very often and was trying to open the trunk without starting the car. (i have 3,200 miles on the car) It must be the car going into a security mode or something.
Thanks for saving me from having to take the Z to my dealer. I hate those guys because they are f'ing dicks. |
08-21-2017, 09:57 AM | #8 |
KaBoom1701
ZL1 in Hawaii must be a very rare thing....
Mods:
08-21-2017, 04:12 PM | #9 | |
08-21-2017, 09:43 PM | #10 |
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300 Join Date: Nov 2011
Just verified this today on my 2012 ZL1. Car running trunk would not open. Pulled up the e-brake trunk opened..
08-22-2017, 12:24 PM | #11 |
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
08-22-2017, 04:48 PM | #12 |
Banned
Drives: Camaro Join Date: Mar 2013
Too much salt air or pakalolo.
08-24-2017, 07:15 PM | #13 |
Drives: Black 2013 ZL-1 Join Date: Jun 2017
same problem with mine.. some kinda stupid safety thing according to this thread
09-01-2017, 07:06 PM | #14 |
Drives: 2014 ZL1 M6 Join Date: May 2017
Mine did the same thing when I bought it. Dealer put in a new switch.
The Widow Maker
2014 ZL1, M6 Kooks LTs, Air Raid CAI, 2.55 upper pulley, D3 reservoir, Elite catch can, ID 850s, flex fuel, DMS auxiliary fuel pump, fasterproms tune |
