10-02-2023, 05:36 PM | #1 |
Drives: 2022 Camaro 1ss 1le Join Date: Jan 2022
Failing oil pump
I have a 2022 SS 1le fbo tuned by gpi. I run full e85 all the time. Last night in heavy traffic I noticed while on a stand still my oil pressure was around 25psi part acceleration is around 40, heavy acceleration is around 42. Haven’t done wot I don’t want to blow the engine lol. Are these symptoms of a failing oil pump? I messaged a local known shop quoted me $1700 for everything with oem pump, should I go with a katech? Or should I do a oil change and see if that’s the problem? Oil seems good and full
Don’t know what part of the forum to post this so this is my second post 🥲 |
10-02-2023, 05:45 PM | #2 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Assuming Mike will chime in any moment... for what its worth... my idle pressure is around 35 and cruising is 40 +/-
25 does sound a little low... but I think the concerning number is 20psi.
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
10-02-2023, 06:05 PM | #3 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
In my experience, idle oil pressure depends on recent load "history", too. Normal idle should be around 30-32 psi, high idle around 34-36 psi, I regularly see both on my car.
That said, I don't recall a single time my oil pressure would've dipped into the 20s. Just a conjecture, but your oil pump may have begun to fail with a hairline crack---if that's the case, it's going to slowly worsen until it reaches the catastrophic failure point around 18-20 psi. The other red flag is your WOT oil pressure, it's way too low and should be 60+ psi (hope I'm not misremembering NA V8 oil pressures, though).
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
10-02-2023, 06:14 PM | #4 |
Yea I kind of figured. I thought by this time gm would of fixed this problem. My car is fbo so I don’t think dealer will want to fix it. Either way 1700 isn’t too much . I’ll change my oil and filter. It’ll fluctuate from 30 to around 25 every couple seconds on idle.
10-02-2023, 06:16 PM | #5 |
Drives: Nickey Super Camaro Join Date: Nov 2008
25lbs is concerning, but yes could be oil issue.
10-02-2023, 06:19 PM | #6 |
I’ve had the same problem on my turbo 5.3 psi was around 20 , changed the oil and it’s been good ever since. Hope this fixes it, I’ll update when I do a oil change on Wednesday . For now it’ll remain parked in my garage
