04-28-2018, 11:59 AM | #1 |
Drives: 2010 CGM Camaro SS Join Date: Dec 2016
Looked at used Camaro ss Potential Issue.
I just looked at a 2012 Camaro ss with 14k at a small independent dealer.
While looking under the hood I noticed the main pulley(harmonic balancer?) had some noticeable wobble to it. The car is out of warranty and nothing on the carfax not even an oil change. Just worried about a bent internal or something that would lead to failure. I have seen some of the SS sedans had the issue as well. Cause for concern? |
04-28-2018, 02:05 PM | #2 |
Mods: If misplaced please move.
Otherwise Bump |
04-28-2018, 05:15 PM | #3 |
376 cubic inches of fun
I would be worried about boy racer mods in general.
04-28-2018, 09:33 PM | #4 |
Drives: Miss Con Ception Join Date: Aug 2016
Look elsewhere. There are other low mileage 5th gens available.
2011 1SS/RS LS3 CGM
04-28-2018, 10:26 PM | #5 |
Not anywhere near me. Has anyone experienced this here with the harmonic balancer pulley wobble?
From what I found early 2000's vettes had this issue as well. What are the ramifications and the cause? Is it just a matter of replacing the pulley wheel or does it originate with the engine crank? |
04-30-2018, 08:04 PM | #6 |
Drives: Black camaro 2ss 45th Join Date: Jan 2018
Could just put an under drive pully on. Get a video of how bad it is
04-30-2018, 08:20 PM | #7 |
I didn't take one as the dealer was standing beside me. I didn't mention my observation and neither did they, clearly. Only 14k on the clock too, had me wondering if the car was modded for that to occur.
04-30-2018, 10:52 PM | #8 | |
If it wasnt tuned DON'T F-around and try to diagnosis the cause & severity of the wobble (oil on HB, cracked, only at idle, engine shake under load,etc) tell the dealer you are REALLY interested BUTTT they first have to replace the HB before you'll even consider going thru with a purchase. |
