06-07-2018, 06:01 PM | #1 |
Drives: 2013 ZL1 Vert Join Date: Aug 2016
Most important items to read on gauges.
I just recently purchased a set of Aeroforce dual gauges.
What is everyone reading (most important) on there gauges? IAT2 Boost trans temp etc... |
06-07-2018, 06:28 PM | #2 |
Drives: 2012 ZL1 Join Date: May 2017
I am changing my Ngauge around a lot. I like to keep an eye on fuel pressure, oil pressure alcohol content, IAT2, knock etc.
06-07-2018, 08:31 PM | #3 |
Drives: Fast Join Date: Mar 2015
IMO, IATs and AFR. Tells you if it's making power and tells you if it's running good/about to blow.
06-07-2018, 08:45 PM | #4 |
ZL1 Pilot
Lambda
Fuel Pressure KR
GP Tuning 2.5 Cam, RPS Carbon Twin Clutch, Ported Blower, Kook's Headers, Cold Air Inductions CAI, ID850's, 9.17 Lower, 2.5 Upper, JMS BAP, Pedders Front Radius Arm Inserts, Whiteline Subframe Inserts, Tuned by me with HP Tuners Idle Clip Link...........https://www.youtube.com/watch?v=gTL8S9eHwbs |
06-07-2018, 10:07 PM | #5 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
IAT, Oil Pressure, Fuel Pressure, Coolant temp.......The gauge will scan through those easily.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
06-08-2018, 09:26 AM | #6 | |
I have the DSX system so I like to see my boost and FP to make sure that my pump is turning on. The thing that I like about the Ngauge is that it has a a couple screens and one of them is a 6pack gauge. I am not sure why people hate on the ngauge because that thing does everything and it works... I consistently run IAT2, IAT, e85%, FP, Boost, and Oil temp with the knock across the lights. I have the zietronix hacker mod frenched into the small piece of plastic above the steering wheel and below the DIC. Sometimes it is a lot to pay attention to but a new motor is a lot of money haha.
764RWHP on e85 683RWHP on 91. M6 Black on Black on Black. 1300ID's, DSX Aux Pump and Flex Fuel Sensor, Lingenfelter 2.5 upper 9.5 lower, 100MM idler, AFCO HX w/ FANS. 1 7/8"ARH exhaust to axle incl LTH, MF's, Fuel Lab FF, Lingenfelter ported snout and TB, Lingenfelter CAI, RotoFab coolant tank, NGK 2 steps colder spark plugs, Moroso catch can, BTR Stage III cam, crank case breather. Tuned by Power Labs in Idaho Falls, ID.
06-08-2018, 12:53 PM | #7 |
Drives: '14 ZL1, Duramax H2 Join Date: Apr 2012
On my Aeroforce gauges I too monitor KR with the warning light (set for 2.5 deg knock)and usually display IAT2 and AFR. I sometimes will use cyclic scan to automatically rotate trans temp/coolant/and oil temp on the bottom display. When drag racing I will sometimes use the scrolling graph to watch KR vs RPM then pause the graph at the end of the track to see if and where I may be getting excessive knock. I don't use the 8 parameter display that often unless I'm trouble shooting something.
06-11-2018, 11:25 AM | #8 |
Drives: 2013 VR ZL1, M6 Join Date: Nov 2017
On my Aeroforce, I constantly monitor IAT2 & Injector Duty %, and have warning lights set for KR.
I do cycle through some other parameters such as misfires, timing advance, and fuel trims.
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
