Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 05-13-2014, 03:32 PM   #1
OPP
OPP's Avatar
Drives: 2018 MBM ZL1 Auto
WARNING ABOUT THE MICHELIN PSS UPGRADE!
I changed my original worn tires with the Michelin Pilot Super Sports (315/35, 295/35). They look and handle great, BUT:
The other day I was driving on the highway through a bend on the road and there was a dip on the road. I was maybe going a little fast for the dip, not the road and my new front "outside" tire got a nice shave on the edge. Apparently the shave came from the top of the front plastic air deflector because I checked the fender and the paint is intact. It wasn't dangerously deep but it shaved about 2-3 mm from the edge of the tire.
Just throwing it out there in case anybody is thinking about upgrading to Michelins. If there is a 285/35 Michelin tire, Iwould go with that for the front.
The rear tires don't look like they will have any rubbing issues.
Update 8/16/14:
FRONT TIRES ARE RUINED. THEY ARE RUBBING ON THE FENDER, NOT THE PLASTIC THING. ONE CUT IS SO DEEP THAT I CAN SEE THE WIRES. ORDERING 285/35 PSSs TODAY. IT'S CURIOUS THAT THE LEFT TIRE IS THE ONE WITH THE MOST DAMAGE. THE RIGHT TIRE HAS A VERY LIGHT RUB ON IT. MUST BE SOME ASYMMETRY ON THE CAR.
Photos of front & rear just after installation.
OPP is offline   Reply With Quote
Old 05-13-2014, 03:34 PM   #2
12 ZL1 #1725
12 ZL1 #1725's Avatar
Drives: 2012 ZL1 Black 6M
I was debating on the 285/295 difference.... This information was very helpful. Ty!!!
Sit Back and Enjoy The Ride!!
12 ZL1 #1725 is offline   Reply With Quote
Old 05-14-2014, 08:36 AM   #3
Rizzo
Drives: 2012 Camaro ZL-1 SIM
Interesting...
I have the same setup. Is your car lowered?
Rizzo is offline   Reply With Quote
Old 05-14-2014, 08:57 AM   #4
LIL QIK
LIL QIK's Avatar
Drives: 2013 ZL1 Camaro
If you wouldn't mind.....please post pics of your cars if running this combo. If possible....from different angles....
Thanks...
2013 ZL1 Camaro - Crystal Red Tint / A6
Best so far of 10.50 @ 134.50 w/ 1.58 60' on 20" Nitto NT05R's (Camaro5 Fest - Royal Purple Raceway)
LIL QIK is offline   Reply With Quote
Old 05-14-2014, 08:57 AM   #5
HDRDTD
I would imagine that if you wanted to, you could put a large chunk of modeling clay on top of the tire, jack the car up high enough to put a 4x4 (or whatever height it would take) under the tire then lower the car until the tire is at max vertical travel.
When you're done, check the modeling clay to see just how much clearance you have at full compression. you can see from any impressions in the clay, just what part of the car comes closest to contacting the tire. you can also repeat the process after turning the steering wheel full in either direction.
Same method people use to measure for valve to piston clearance.
Old 05-14-2014, 02:20 PM   #6
2014CamaroZL1
2014CamaroZL1's Avatar
Drives: 2014 CRT ZL1
I also have the 295/315 combo.
However, my slight rubbing is in the back.
The tire against the rear mud guard, but only over sudden deep depressions in the road.
Usually only with another person in the car.
I have a full-size-ish spare and sub in the trunk, so my back may sit a bit lower than stock.
2014CamaroZL1 is offline   Reply With Quote
Old 05-14-2014, 04:23 PM   #7
cvp33
America FVCK Yeah!
cvp33's Avatar
Drives: 2021 ZL1 1LE A10
Michelins are notoriously wider than every other tire. Still surprised to hear that 315's are rubbing though.
cvp33 is offline   Reply With Quote
Old 05-15-2014, 04:55 AM   #8
OPP
OPP's Avatar
Updated with pics
Old 05-15-2014, 01:21 PM   #9
2014CamaroZL1
Are you certain that the rubbing was in the front ?
There seems to be so much clearance in the front.
Also...on the pictured wheel, there are no marks on the tire indicating that a rub occurred.
Unless it was on the tread edge and subsequently wore away.
On my back tire, you can clearly see a light mark around the tire where it briefly rubbed.
Old 05-15-2014, 03:54 PM   #10
OPP
OPP's Avatar
These pictures were on the day they got installed. They got shaved later. I am certain it was that plastic because it was a slight bend to the right on the road which would put the edge of the tire in line with that plastic and if you feel that plastic with your finger, it's sharp. I already filed the plastic so it's not sharp anymore. Also the shave is kind of hinge-like on some of the treads, with the "hinge" being towards the center of the tire. The only thing that could have cut it from "outside" is that damn plastic.
I was basically driving at the wrong speed on the wrong bend on the wrong road at the wrong time.
Another thing, a friend of mine has another ZL1 and mine is a little lower than his. But I say his car is higher than mine. We don't know which is correct.
Old 05-15-2014, 04:20 PM   #11
Todd in Vancouver
Todd in Vancouver's Avatar
Drives: 2014 ZL1
Please keep us updated on how it goes after you filed the plastic edge and if it continues to happen. This is the exact combo I was looking at after my GY's go Bye-bye. Friend of mine went to the PSS from the GY and said he finds they stick just as well on track days and are much more driver friendly for living on the Wet coast like we do. So this kind of info is really important on if I size up or stay close to what we have with the GY.
Todd in Vancouver
'14 ZL1 Camaro
'67 Camaro SS Pro-tour in process
How hard can it be...
Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession
Todd in Vancouver is offline   Reply With Quote
Old 05-15-2014, 07:54 PM   #12
2014CamaroZL1
Ultimately, it is the best choice for a dry/wet summer street tire.
Mine only rubs a bit, when loaded a bit and under heavy sudden compression.
Any slight damage to the plastic part on which it rubs is not noticeable, as it is probably the inner edge of the rear splash guard.
Just gotta live with the occasional rub noise.
No biggie.
Hopefully the same for the front end rubbers.
Old 05-15-2014, 07:56 PM   #13
v8
v8's Avatar
Drives: 19 Z06
Thanks for the information, good post
Gone but not forgotten:
1974 Corvette Stingray 454
1986 Z28
2009 Mustang GT convertible
2012 45th 2SS Vert
2013 ZL1 M6
2014 Zl1 M6
2014 GT500
2016 Challenger Hellcat M6
www.youtube.com/c/garageking
v8 is offline   Reply With Quote
Old 05-16-2014, 08:49 AM   #14
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Thanks for posting, I was considering the front 295/35 myself.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
