Old 11-09-2018, 11:33 PM   #1
BAH2SS
Stigs Bahraini Cousin
BAH2SS's Avatar
Drives: 2015 Camaro 2SS 1LE
Exclamation LUK clutch kit?
I guess we all know that LUK makes the clutches for GM cars including corvettes. I am getting a clutch kit for my 10' ss but got stumbled upon two different part numbers.
LUK 04-216
LUK 04-263
product description says one of them is for the 10' camaro & the other one is for a 05-11 corvette.
Is there any difference between them, the only thing i see different is the slave cylinder one of them has I think is the oil feed tube.
Which one should i get and do i have to get a flywheel as well?
EDIT: I am swapping out my Mcloud RXT out and the reason is it slips when the clutch is cold. some say its normal for mcloud to do that and others say it time to replace. Once the clutch gains heat a bit it grips great.
2015 CAMARO 1LE
https://www.camaro5.com/forums/image.php?u=143224&type=sigpic&dateline=1541618573
BAH2SS is offline   Reply With Quote
Old 11-10-2018, 01:35 PM   #2
xc_SS/RS
Drives: 2010 Camaro SS/RS
Get the one for the Camaro. It's got a Camaro specific slave cylinder. I just installed 04-263 with a fidanza flywheel. Highly recommend it to reduce some weight
I think it's recommended to replace the flywheel as well. Not sure if it can be turned, but if you're going from the RXT to stock then you will definitely need a LS2/3/7 specific flywheel.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 11-11-2018, 12:29 AM   #3
BAH2SS
BAH2SS's Avatar
Thanks for the input. Steel or Aluminium flywheel?
2015 CAMARO 1LE
Old 11-11-2018, 11:00 AM   #4
xc_SS/RS
of course! mine is aluminium and it weighs 13.5 pounds. there is also a steel flywheel from Ram that weighs 19.x i believe.
stock is like 27 pounds lol
2010 2SS/RS
Old 11-20-2018, 03:12 PM   #5
BAH2SS
BAH2SS's Avatar
Q: Is it ok to install the clutch kit with the mcloud flywheel or do i have to change the flywheel as well?
That's if the flywheel is good.
2015 CAMARO 1LE
Old 11-20-2018, 05:44 PM   #6
xc_SS/RS
I would imagine you'll need a new flywheel if you're going to the Luk/OEM clutch. But to really be sure I'd call Mcloud to clarify
2010 2SS/RS
