07-10-2018, 07:52 AM | #1 |
Drives: 10 SS A6 Huron TT Join Date: Oct 2016
Toe link upgrade question?
So I am looking to upgrade the rear toe links on my 2010 SS. I already have Pfadt trailing arms.
1st, if I mark the bolts, will everything be aligned correctly and I will not need to go to an alignment shop? 2nd, I see some brands do not have clip holders for the harness... Would there be any issue if I install these links (Lakewood) vs installing the ones that have retainers for the harness? Thanks!
2010 2SS RS / A6 and Sunroof / Huron Speed TT / cam/ E85 fuel system / 3200 stall / SBE
07-10-2018, 01:06 PM | #2 |
Drives: 2009 ZR1 Join Date: May 2010
1. You'll still need an alignment but it will get you by for a bit. Think about it - alignments are done by degrees. I doubt you'll get it exactly the way it was but you can get close. Maybe use 2 or 3 marks to line everything back up.
2. Just use zip ties to hold the harness in place. |
