Old 02-10-2020, 10:29 PM   #1
Screwblower
Drives: 14' 2ss convertible
Water in the front passenger floor board?
The rear on both sides completely dry. The trunk and battery compartment dry.
The cowl area and drain are in good shape without debris.
How does water get in the passenger front foot well?
Down south and have had 5 inches of rain and sideways down pours due to high winds.
Car is garaged but driven everyday for now.
Screwblower is offline   Reply With Quote
Old 02-11-2020, 12:48 AM   #2
theragtopguy
Lifetime Philly Fan
theragtopguy's Avatar
Drives: 2015 Spring Edition 2SS M-6
Could be a bad door seal. Look for water tracks on the plastic.
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter
BBK LT HEADERS 1 7/8”
Tune by DynoSteve via SCTx4 Tuner
One of 82 GF Ragtops built in '15 out of 811 Total
[/SIZE]
theragtopguy is offline   Reply With Quote
Old 04-26-2020, 10:12 AM   #3
uvraise
uvraise's Avatar
Drives: 2021 Camaro SS Convertible
Could be your heater core as well.
2015 SS2/RS, SCT Tune (Dynosteve), Vitesse Throttle Controller, Vararam VR-DRX CAI, Vararam Power Wedge TBS, Granatelli Performance MAF
uvraise is offline   Reply With Quote
Old 04-26-2020, 10:17 AM   #4
SSammy
SSammy's Avatar
Drives: 2015 2SS A6 Commemorative Edition
I’d guess heater core. Soak some up with a white towel or rag and see if it’s colored like your antifreeze.
SSammy is offline   Reply With Quote
Old 05-08-2020, 02:28 PM   #5
sbubbaklein
sbubbaklein's Avatar
Drives: early 2011 Camaro convertible
If car is stored in garage, how does it get wet ? Doesn’t make sense.
Early 2011 LT Convertible, ZL1 bumper, hood, side skirts, belly pan and wheels, Truecarbon ECF hood extractor, K&N CAI, Elite catch can, Big Worm Bow Tie emblems, Jacfab bracket, Vitesse TC, BMR strut brace, BMR tunnel brace, NPP exhaust
sbubbaklein is offline   Reply With Quote
Old 05-08-2020, 02:47 PM   #6
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Air-conditioning condensate drain plugged?
Sent from my Pixel XL using Tapatalk
Old 05-08-2020, 07:38 PM   #7
Screwblower
The door was partially shut or not shut well leaving the window down . The auto roll down of the window , never went back up .
My kid didn’t shut the door which caused a minor freak out by me after reading so many water stories on the forum.
