Old 01-11-2019, 03:09 AM   #1
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
Drives: 2015 2SS/RS CV CE
Question Suspension vs Wheel Size & Offset
I'm wondering if a Camaro 2.0T with 18x8.5 32mm offset wheels from the factory and a Camaro 2.0T with 20x8.5 25mm offset wheels from the factory have identical or different suspension setups?
I posted the question in the Camaro6 forum but they don't seem to be communicative there.
PDXSSCE is offline   Reply With Quote
Old 01-11-2019, 06:01 AM   #2
Avenging Orange
Avenging Orange's Avatar
Not sure what you are asking. But changing wheels will not require any suspension modification.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 01-11-2019, 12:52 PM   #3
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
I'm curious if the factory adjusts the suspension based on the offset of the wheels.
I also don't understand why the 18" and 20" offsets are different when the width of the wheels are the same? I thought the diameter doesn't affect the offset.
Old 01-11-2019, 01:35 PM   #4
Vegas Bound
Drives: 2013 Sparkly Red One
7mm is just over 1/4". I can't imagine it would matter.
Vegas Bound is offline   Reply With Quote
Old 01-11-2019, 07:17 PM   #5
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Are the sizes paired up with appearance packages? That may be part of it
HOJO is offline   Reply With Quote
Old 01-11-2019, 08:51 PM   #6
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
The 20x8.5 25mm offset wheels are part of the RS package, but sorry I don't understand how that affects the offset.
Edit: It appears that it's to give it a more aggressive stance, but from a performance aspect, is the higher offset (if the diameters were equal) better because it brings the wheels in?
Old 01-12-2019, 08:56 PM   #7
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Just a guess, but...
Lower profile tires generally have a wider tread than higher profile tires. That will require more effort to steer.
By moving the tires in there will be more leverage to turn the wheels.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
