Homepage Garage Wiki Register Social Groups Calendar Search Today's Posts Mark Forums Read
#Camaro6
Old 12-24-2017, 08:07 AM   #1
mbar
Drives: 2016 1SS
For once and for all - ZL1 brake pads recap
There are dozens of threads with correct and incorrect pads information. So far I gathered that the FRONT pad size is 1835 or 1395 ( 189.7 mm wide / 96.6 mm tall).
Which pads did you confirm that fit, both track and daily driver pads. Please share name and model number (rear pads are easier to find).
I’ll start:
Raybestos ST43/ST41 size 1835 available at Portrefield (they cut them)
Power Stop Z26-1835.
Stock GM 23399101
1SS, Black, Black Wheels, A8, MRC, NPP
mbar is offline   Reply With Quote
Old 12-24-2017, 09:27 AM   #2
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
I’m under the impression that pads for the 2016 CTSV are identical.
seanblurr is offline   Reply With Quote
Old 12-24-2017, 09:39 AM   #3
jbp8653
jbp8653's Avatar
Drives: 2017 ZL1,2013 ZR1, 1952 C3100 Resto
Power Stop 1053/1835. Have them on mine. Exact size of the factory ones I took off. 3500 miles or so with no issues and no dust! And CTS-V are the same
2017 ZL1,Mosaic Black, auto,nav/pdr, Roto Fab,Mamo
2013 ZR1 60th Anniv.
1952 C3100 resto-rod. LS6, 4L60e, 228R cam
jbp8653 is offline   Reply With Quote
Old 12-24-2017, 12:53 PM   #4
mbar
Drives: 2016 1SS
I agree, yet which pads are available?
Old 12-24-2017, 01:01 PM   #5
SociallyAwk
SociallyAwk's Avatar
Drives: '17 SS 1LE
Do ZL1 and SS1LE models share the same size?
SociallyAwk is offline   Reply With Quote
Old 12-24-2017, 01:22 PM   #6
mbar
Drives: 2016 1SS
EDIT:
No. They have different pads
See pic
Old 12-24-2017, 01:44 PM   #7
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
No. SS 1LE calipers/pads/rotors are smaller than ZL1
Provoste is offline   Reply With Quote
Old 12-24-2017, 01:46 PM   #8
Provoste
Provoste's Avatar
Originally Posted by mbar View Post
Yes, just a different caliper color.
Guessing you misread his question. ZL1 and ZL1 1LE are the same, just different color calipers. SS 1LE has smaller calipers/pads/rotors.
Old 12-24-2017, 02:13 PM   #9
SociallyAwk
Drives: '17 SS 1LE
Ah, thank you
Old 12-24-2017, 02:37 PM   #10
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
KNS Brakes has a lot available for track pads.
Old 12-24-2017, 02:52 PM   #11
mbar
Drives: 2016 1SS
I need to give them a call. They have inconsistencies in their website. 2016
CTS-V show different options than 2017 ZL1. Also their website does not share spesific model numbers so I could confirm they have the correct size.
Old 12-24-2017, 02:54 PM   #12
mbar
Drives: 2016 1SS
Ooops. ZL1 and ZL1 1LE is the same lad but different caliper color
Old 12-24-2017, 05:23 PM   #13
RandRZL1
RandRZL1's Avatar
Drives: 2018 ZL1
Following!
RandRZL1 is offline   Reply With Quote
Old 12-24-2017, 05:58 PM   #14
travislambert
travislambert's Avatar
Drives: '17 ZL1
2016 CTSV shows part # 23399101, which is the same # as the ZL1.
A guy I work with has one as a daily driver. The brakes are the same as the ZL1.
I installed 23399101, and they were IDENTICAL to the stock ZL1 pads.
2023 Camaro SS 1LE A10
2023 Camaro ZL1 1LE M6
2017 Camaro ZL1 M6
2016 Camaro SS M6 w/LT4 (Sold)
travislambert is offline   Reply With Quote
