07-05-2014, 10:27 PM | #1 |
"Gunny"
Drives: 2023 Camaro LT1 RS Radiant Red Join Date: Jul 2013
Fan blower squealing ?
Took the beast into the dealer because of a noise coming from the blower motor, it squeals at all speeds, the local dealer thinks it MAY be some dirt rubbing the fan blade or a PEICE of debris that is caught between the fan and the shroud in the blower housing... I think it's a bearing etc.. They told me it wasn't under warranty if it's dirt, but would be if it's a mechanical issue, but the only way they can tell is tear it apart and check it out, but it will cost a ton if it's dirt etc... Does anyone else have this issue ? Before I take it in for the repair.... Thanks...mjclemm...
07-05-2014, 11:02 PM | #2 |
Drives: FOR SALE! Bumblebee 1 of 1 Join Date: May 2010
This has been covered already. Design issue with the fan itself is the most likely cause. I cleaned mine, pushed on it and it stopped most of the noise. Every so often it returns though. Easy access yourself though the plastic should in front of the windshield.
My 1 of 1 Bumblebee: Paint=House of Kolor Sunrise. Shaved door handles and concept handles added. Shark fin removed, concept mirrors, Showstoppers concept LED side marker lights. Wiper blades removed, muffler delete, and Range AFM disable. BMR springs lowered 1" rear and 1.4" front and added Eibach wheel spacers - 20mm rear and 25mm front.
07-06-2014, 08:30 AM | #3 | |
"Gunny"
07-06-2014, 05:21 PM | #4 |
376 cubic inches of fun
There have been a number of threads on this. The typical symptom is squeaking at low fan speeds, from new. If yours started just recently, maybe it is debris. Blower replacement is a huge job, so better to be sure.
FWIW, mine squeaked when new, at low speed only, then stopped after a couple of years. |
07-08-2014, 10:49 PM | #5 | |
"Gunny"
