06-28-2015, 09:16 PM | #1 |
Banned
Drives: 2013 Camaro 2SS/RS Join Date: Jan 2014
Putting higher than 93 octane in a stock non tuned SS?
What can I expect putting higher than 93 octane in a stock non tuned SS?
I know I will not benefit from additional hp, power, etc. but will it run better? I am going to the track which they have race fuel pumps and was wondering? |
06-28-2015, 09:28 PM | #2 |
Banned
Drives: Camaro Join Date: Mar 2013
High octane gasoline burns slower than low octane gasoline. The slow burn prevents engine knock when cylinder pressures are high. If your engine runs well and does not knock or ping on low octane gasoline, there is no advantage in switching to higher octane gasoline.
06-28-2015, 09:54 PM | #3 |
In less words, no.
06-28-2015, 09:54 PM | #4 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
Being that the car is rich from the factory and still knocks about 4-6 degrees, if the higher octane prevents some of that knocking, you'll pick up a couple HP.
06-28-2015, 10:06 PM | #5 | |
Drives: 2013 Camaro SS (+RS) + Hurst+ DME Join Date: Sep 2012
06-28-2015, 10:10 PM | #6 | |
Drives: ‘13 1LE Join Date: Jul 2013
What was the fuel's AKI number when you observed KR? At what rpm did the KR occur at? |
06-29-2015, 07:49 AM | #7 |
Drives: 2014 Camaro 2SS/RS M6 Join Date: Apr 2014
Get tuned for it like I did, running sunoco 260 gt 100 unleaded. Picked up 30hp from 93.
2014 2SS/RS M6-ZL1 SHORT THROW-Z28 INTAKE-KOOKS 1 7/8 CATLESS HEADERS-NPP EXHAUST-TUNED BY STEVE AT RDP ON 100 OCTANE-446 WHP-412 WTQ
06-29-2015, 09:50 AM | #8 |
If you tune for a higher octane like that, you always need to run that level octane. That's why I tell guys not to add fuel oxygzers on tune day unless you plan to run it every day like that. Sure you'll get a higher number, but I dont like the risk Vs return if you dont run that adder every day because your traveling away from your favorate fuelling station
06-29-2015, 10:36 AM | #9 | |
06-29-2015, 11:24 AM | #10 | |
Drives: 2011 LS Black on Black 6speed Join Date: Jun 2011
OP is stock! Not bashing but I think tuning your car to run on basically "race Gas" for under 500hp is really not worth it. Many Mods you can do on pump gas to achieve this.
Roto-Fab CAI-Ported Throttle Body-Black Ice Isolator-Flow Master Axle Back-RX-Catch Can-Hurst Short Throw Shifter-Trifecta Tune\Ghost Cam Phantom Billet Grill-Billet Fuel Door-Side Gills-Headlight Armor Black Out Kit-Zenik Rims-Lowering Springs-MGP Caliper Covers-Dome\Trunk\Footwell Lighting. |
06-29-2015, 11:51 AM | #11 |
Drives: 2019 Corvette Grand Sport Join Date: Dec 2014
06-29-2015, 11:52 PM | #12 |
Drives: 2015 2SS/RS/1LE Join Date: Feb 2015
Or do the mods, bump up compression, and run the race gas permanently to pick up 30+ over what the mods would pick up. Just sayin'
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports. |
06-30-2015, 06:19 AM | #13 | |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
I would never recommending tuning for a particular grade of racing fuel like that, but hey, it's your grenade. For stock, and if you have 93 pump gas plentiful around you, tune for that and call it a day. If you want more, put headers on it. From a cost standpoint, considering that the Sunoco at 7 bucks/gal is about double what you pay, you could pay for those headers quickly than "renting" the HP through the gas. Using 93 and at say, 20 mpg, the headers could pay for themselves in about 8500 miles.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
06-30-2015, 01:37 PM | #14 |
