Old 09-25-2017, 06:23 PM   #1
redcoats1976
key problem
about 30% of the time when i turn off the engine and attempt to remove the key it wont release,have to mess with the shifter until it does.dealer said the shifter needs to be replaced(under warranty)anyone else have this problem?
Old 09-25-2017, 07:17 PM   #2
PeteD
PeteD's Avatar
Drives: 2012 2SS Victory Red with white st
Never heard of that one. I assume yours is an auto?
PeteD is offline   Reply With Quote
Old 09-25-2017, 09:20 PM   #3
Talladega
Talladega's Avatar
Drives: 2013 Camaro SS
If it's under warranty let them do it.
Talladega is offline   Reply With Quote
Old 09-25-2017, 09:42 PM   #4
wildchevy
wildchevy's Avatar
Drives: 2018 Hyper Blue 2SS convertible
Had this happen to a different model, the phone cord was in the way not allowing the shifter to go all the way forward into park, worth a look see.
wildchevy is offline   Reply With Quote
Old 09-25-2017, 09:59 PM   #5
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Happened to a car my daughter owned years ago. The key release is tied to the shifter being in park; I believe there is some type of switch or toggle the shifter presses against when in park that 'releases the lock'. Regardless, they replaced her shifter (also under warranty at the time) and she never had the problem again.
Welker2 is online now   Reply With Quote
Old 09-26-2017, 02:51 AM   #6
redcoats1976
good to know.just thought i would put it out there in case anyone else was having this problem.taking it to the dealer friday.
Old 09-26-2017, 08:32 AM   #7
Junior
Junior's Avatar
Drives: 2014 2SS/RS A6 AGM
Send a message via Skype™ to Junior
This is common. IIRC there is a simple fix detailed on this forum. Here is the first one I found while searching:
http://www.camaro5.com/forums/showpo...0&postcount=12
Junior is offline   Reply With Quote
Old 09-26-2017, 05:30 PM   #8
redcoats1976
car is under bumper to bumper warantee,im going to let them do the right thing.
