09-19-2020, 10:03 PM | #1 |
Russ
Has anyone done damage to your engine from nitrous?
I just bought a nitrous kit for my 2010 Camaro SS but I haven't had it installed yet. I've read about people blowing their cars up after installing nitrous and I've read that people have used with no problems. The installer that I talked to told me that with the newer nitrous systems they are much safer to use than ever before. They come with the sensors they have now the NOS wouldn't inject if there was a problem with the engine. I've never ran NOS so it's all new to me but I don't want to take a chance in blowing up my engine.
I read the sticky on NOS which was very helpful and the post suggested it's not dangerous when installed and used correctly......I just want to make sure I do everything I can to not damage my engine. |
09-19-2020, 10:53 PM | #2 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
I have, was not a ls3 tho. Was a Blue Print engines 383 stroker, broke connecting rod and destroyed the motor. Have not used nitrous scene
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
09-20-2020, 05:15 AM | #3 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
There's always that what if with nitrous. Just last night I watched a car blow its intake apart from a nitrous backfire.
I would look into another power adder. Single turbo kits from huron will be in the same price point as a well put together nitrous kit. Just something to think about
09-20-2020, 07:13 AM | #4 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
1)Never spray under 3000 rpm.
2)Make sure your tune is richer at WOT and you pull the timing back 2 or 3 degrees per 100 hp. 3)Don't get greedy 100 to 150 max on a stock bottom end. 4) Use as many safety systems as you can(low FP cut off,nitrous timer,rpm switch ect) Do your research go to the different systems web sites and read.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
09-20-2020, 10:44 AM | #5 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
I had a 100 shot on another car. I set it up to only work at wot. I also tapped the fuel rail for additional fuel supply to the nozzle. The setup worked like a charm and was very safe. Like others said, don't get greedy with it, proper setup, and failsafes will all work together to prevent detonation. Of course no guarantee though.
Go with an lsa or single turbo instead.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
09-20-2020, 08:54 PM | #6 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
I’m aware of several instances of buddies mishaps:
1. Burnt a plug tip which took out a cylinder due to too lean 2. Nitrous backfired that split the SC pan underneath. I don’t know what causes them. 3. Killing cylinders due to forgetting to manually turn on race fuel cell with the octaned fuel. So, that was running too much timing for the street octane gas.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
09-20-2020, 08:59 PM | #7 |
Drives: 2013 Camaro 2SS/RS Join Date: Aug 2020
I have always left this to the big boys. Dominic "Dom" Toretto, for example. He can do it...no problems.
09-21-2020, 11:31 AM | #8 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
With nitrous, it is just a matter of when...
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
10-07-2020, 02:28 PM | #9 |
-Rad Air CAI
-GPI SS3 Cam & BTR Springs -2" Texas Speed Headers -AEM Wideband AFR -3" Full Exhaust w/Hi-Flow Cats & Single Chamber Flowmasters -McLeod RXT twin-disc w/Aluminum Flywheel -Yukon 4.11 -Nitto 555 G2 |
Thread Tools | |
