11-04-2015, 08:46 PM | #1 |
Drives: 2013 HWSE Indy Festial #26 Join Date: Mar 2011
All cracked up!
I was wondering if anyone else has these cracks under their splitter. I just noticed them tonight while under the car for some detailing and just a general look see.
My Z/28 has 360 miles on it. I didn't expect to see these cracks when I looked underneath. The cracks are nearly identical and they are on both sides of the splitter. About an inch or two back from the leading edge. If someone would check theirs, I'd appreciate it. If it was just one side, I think it might be a different problem. But both sides? Me thinks defect. Thoughts?
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan |
11-04-2015, 09:05 PM | #2 |
Drives: 2014 Z/28 # 89, 69 Camaro, 2013 ZL1 Join Date: Jul 2013
Nope. just checked
11-04-2015, 09:18 PM | #3 |
Drives: '16 C7 Z51 Join Date: May 2012
It probably happened when bumper was hit by you or the dealer, and it cracked from the weakest stress points which happen to be those locations.
When in doubt, always slow to crawl when entering bumps. If you hit it, which happens to everyone, it would be more likely to flex than crack when very slow.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
11-04-2015, 09:30 PM | #4 | |
Thanks for the driving tips. I never thought about slowing down going over bumps in a $76,000 car.
Dan |
11-04-2015, 09:35 PM | #5 | |
I wasn't trying to be a smartass, but when my brother told me to 'almost stop' over bumps, it made a huge difference, and I stopped scraping the bottom of it. Well, this was a decade ago, back when we owned a C5 Z06. EDIT: FYI, I do have the full Z/28 aero.
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD Last edited by X25; 11-05-2015 at 04:03 AM. |
11-04-2015, 11:06 PM | #6 |
Drives: 2015 Z/28 Black, A/C, Stereo Join Date: Oct 2015
Just checked mine, no cracking. I did notice the outer edges are chewed up though, so its definitely scraped. :/
The rubber flaps seem to be there to direct air passing under away from the wheels? Last edited by Immortan; 11-05-2015 at 06:11 AM. |
11-05-2015, 03:58 AM | #7 |
Drives: '21 ZLE A10 Join Date: May 2012
I've scraped the piss out of mine but no cracks. ^^^ funny stuff ^^^
11-05-2015, 06:53 AM | #8 |
Honestly, it could have somehow happened at the dealer. The car had 60 miles on it when I bought it. (Yes, I knew what I was possibly getting in to). I know I haven't hit anything, nor are there any scrapes at all underneath and no signs of damage on the leading edge or the top. It looks like stress cracks of some sort and since they were on both sides I thought I may have found something.
Hopefully someone else will chime in that has the cracks, but I might be relegated to living with it for now and replacing it down the road when I actually do go too fast over a bump and really bang it up! Thanks guys for the responses. Even X25!
Dan |
11-05-2015, 07:57 AM | #9 |
Drives: 2015 camaro z/28 Join Date: Oct 2015
Mine also has the cracks. Same exact spots. I seen a silver z at the Chevrolet display at the races the other day that had the cracks also.
11-05-2015, 08:06 AM | #10 |
Just checked mine. Car has 620 miles on it and both sides are cracked in the same spot as yours, but not nearly as bad.
1 1/2" crack on the drivers side. 1/2 " on the passenger side. No scrape or impact marks anywhere, and I've never had a fight with a speed bump.
11-05-2015, 01:09 PM | #11 |
I'm going to the dealer in the morning. I'll let everyone know what comes of it.
Dan |
11-05-2015, 04:50 PM | #12 |
must be a bad mold or weak "fiberplastic"...yeah, I made that up. I doubt anything happened to cause it and the dealer will order a new unit ASAP as a warranty item. Good luck & report your findings at the dealer.
11-05-2015, 07:05 PM | #13 | |
I didn't look over everything, but is that just a bottom piece or would the entire splitter have to be replaced?
2015 Z/28
A/C and audio |
11-05-2015, 07:10 PM | #14 |
I am going tomorrow. Friday morning. It looks like the entire splitter has to be replaced to me.
Do these things come already painted? This could be an event getting this replaced. There might be a run on this part in the supply system, so I'm glad I'm going tomorrow!
Dan |
