Old 06-09-2016, 10:14 PM   #1
razorz28
razorz28's Avatar
Drives: 2017 Jeep Rubicon, 2016 Z06
Lower Front Drivers Seat
I am interested in having the front seat lowered to the floor, has anyone done this or know if it can be done. I cannot sit comfortably in the car with a helmet on.
2014 Z/28 Black VIN #176
razorz28 is offline   Reply With Quote
Old 06-10-2016, 07:16 AM   #2
Doug Halsey
Toy Collector
Doug Halsey's Avatar
Drives: 2015 Camaro Z/28
Have you adjusted the seat height? I know I bought mine and it was set up perfectly so I never tried adjusting it until my first track day. Reason, with the helmet on I was hitting the roof with it. I didn't have the owners manual with me so I lived with it because no one else could figure out how to lower it.
Later I read the manual and figured out how to do that. So now it goes as low As I need it for track days.
Doug Halsey is offline   Reply With Quote
Old 06-10-2016, 08:45 AM   #3
razorz28
razorz28's Avatar
Hi, thanks for the response. Unfortunately I have adjusted the height it's as low as it goes.
Old 06-10-2016, 08:47 AM   #4
2015Z28
Drives: 2015 Z28 #516
I have had my seats apart and you could easily have the bottom cushion shaved thinner to sit you lower too.
2015Z28 is offline   Reply With Quote
Old 06-10-2016, 09:08 AM   #5
JTRATX
Drives: 17 SS 1LE, 14 Yukon Denali
I'm in the same boat. I hunch down in the seat, not comfortable, but no other options.
I went so far as to try and make some brackets to remove the seat sliders, but couldn't make it work.
Didn't think of having a thinner seat cushion made. May have to look into that.
JTRATX is offline   Reply With Quote
Old 06-10-2016, 07:02 PM   #6
Fastduo
Drives: 2015 Z28 Silver w/AC
I am considering a Kirkey or Butler built aluminum seat just for track days. Anyone else done this?
Fastduo is offline   Reply With Quote
Old 06-10-2016, 08:22 PM   #7
Spyglass
Drives: Too many
Make sure you are completely up to date with the rules of Organization you track with. If you run an aftermarket seat you'll have to get a 5 or 6 point aftermarket belt. I learned that the hard way. It's definitely for your own safety but sucks to hear it on track day.
Spyglass is offline   Reply With Quote
Old 06-10-2016, 11:07 PM   #8
Z28-TX
Drives: 2015 Z-28 / '13 Howe TA2 Camaro
Head Room
Check out this post.
http://www.camaro5.com/forums/showthread.php?t=415670
Z28-TX is offline   Reply With Quote
Old 06-11-2016, 12:59 AM   #9
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
That was a hard lesson to learn. It defeats the purpose of a race seat to use a three point stock seat belt. So much better having that anti submarine belt in a race seat. It definitely holds you in place when under a heavy braking. Schroth makes a street legal 4 point detachable belt. I used them with great success on another car that I did a track day with years ago. This time around nothing but 5 point belts and a Hans device.
ZL1-V is offline   Reply With Quote
Old 06-11-2016, 11:32 AM   #10
Spyglass
Drives: Too many
ZL1-V
Yes indeed. The Recaros are great but a purpose built race seat keeps you planted. I never tried a Hans. Maybe in the future.
Old 06-12-2016, 09:39 PM   #11
cscamaro
cscamaro's Avatar
Drives: 2013 ZL1. Black on black
yes still trying to lower the seat track days are a bitch
cscamaro is offline   Reply With Quote
