#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
AWE Tuning
Old 03-15-2018, 12:55 PM   #1
tnspd
tnspd's Avatar
Drives: 18 Camaro ZL1 1LE (WILSON)
ARH 1 7/8 Headers with Long system install
I am installing the ARH 1 7/8 Headers with the long system on my 2018 ZL1 1LE. I searched the forum but did not find what I am looking for.
Where do I cut the pipe at to hook the long system into the Factor Muffler? I know I cut it after the smashed part of the pipe but what do I measure on and what is the measurement?
tnspd is offline   Reply With Quote
Old 03-15-2018, 01:18 PM   #2
TJay74
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC
The install should tell you, it is around 6"-12" before the muffler where you cut.
TJay74 is offline   Reply With Quote
Old 03-15-2018, 01:22 PM   #3
tnspd
tnspd's Avatar
The picture they sent says measure 11.5 inches and cut but I cannot tell from the pucture where to measure the 11.5 inches from.
Sent from my SM-G900P using Tapatalk
Old 03-15-2018, 05:26 PM   #4
marknagy13
Markoon13
marknagy13's Avatar
Drives: Camaro 2SS
If you are unsure then just cut the pipe in the back extra long just to be safe, start to install the system and see where it lines up to.
marknagy13 is offline   Reply With Quote
Old 03-18-2018, 03:10 AM   #5
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
mine came with no instructions.
what I did is put the new on top of the old and lined up the rear hangers. mark the old and cut. on mine it was 13" from the rear hangers to the cut. it gives you quite a bit of leeway. to make sure the tips are equal look at your hangers. there will be a polished line on the rear hangers. just move the muffler to were it was befor.
JCunningham is offline   Reply With Quote
Old 03-20-2018, 07:56 AM   #6
tnspd
tnspd's Avatar
I got my headers and my new CAI installed and I am very pleased with the ARH headers and the cols air inductions CAI.
