#Camaro6
Old 05-06-2018, 10:18 PM   #1
Idaho ZL1
Drives: 1967 RS/SS 427, 2018 HPB ZL1 1LE
1LE track wheels .... MMR?
I brought my 1LE, brought it home and put MP4s tires on it. I love them on the street. I have the stock 3R tires and plan on trailering to a couple of tracks this summer. probably Salt lake and Vegas. I want a set of track wheels. I know MMR make replicas, but am unsure of the side loading. what is the best 19" wheels to buy?
2018 HPB ZL1 1LE
1967 Marina Blue RS/SS 427
Idaho ZL1 is offline   Reply With Quote
Old 05-06-2018, 11:01 PM   #2
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Don't get MRR's, they don't offer anything in the stock size. I would get another set of OEM wheels or a custom forged set. I have two OEM wheel sets and a set from BC Forged. One has PS4's, the other two have different track tires.
seanblurr is offline   Reply With Quote
Old 05-07-2018, 05:52 AM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
MRR are only 20". 19" are preferable.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 05-07-2018, 07:04 AM   #4
Canadamaster
Drives: Future zl1 1le
https://www.phastekperformance.com/2...9.htm?CartID=1
They make 19's I'm getting these for my second set love the OEM look
Canadamaster is offline   Reply With Quote
Old 05-07-2018, 07:23 AM   #5
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Those aren’t the same specs as OEM, why do that?
Old 05-08-2018, 01:53 AM   #6
mr965
mr965's Avatar
Drives: ///M3
Ditto
mr965 is offline   Reply With Quote
Old 05-08-2018, 09:21 AM   #7
rjacobs
Drives: none
I wouldnt want to run a cast set as track wheels personally.
rjacobs is offline   Reply With Quote
Old 05-08-2018, 11:12 AM   #8
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Seems like 19 opens up to more tire selections and while MMR will not be as strong as a forged wheel just inspect em after each Trackday for cracks.
thescreensavers is offline   Reply With Quote
Old 05-08-2018, 11:25 AM   #9
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
The 19" MMRs are NOT 19x11 and 19x12 like Factory OEM ZL1 1LE wheels. They're narrower and made to fit on regular SS/ZL1s. If you want 19" wheels in ZL1 1LE spec, you're going to have to go aftermarket completely unless you just want to buy another OEM set which is going to run $2500-$3000.
Can'tHave2MuchHP is offline   Reply With Quote
Old 05-08-2018, 08:56 PM   #10
likerage
Drives: 2018 Camaro ZL1
Originally Posted by Phastek description
Construction: Flow Forged
This might work perfectly for me. I dont plan on tracking at all. I'd like to improve the tire options and lighten the weight of the wheels at the same time. Though I cant seem to find the listed weight. If its the same as a 20" its useless.
likerage is offline   Reply With Quote
Old 05-08-2018, 10:23 PM   #11
rjacobs
Drives: none
flow forging is not forging... it takes a cast wheel and then the manufacturer does a process to it to get it to its final size and shape on the barrel. The spokes are still cast.
Its an in between straight cast and full forged.
I can almost guarantee the 19" MMR wheels are heavier than the factory 20" fully forged wheels or at least the same weight.
Old 05-08-2018, 11:32 PM   #12
mr965
mr965's Avatar
Drives: ///M3
I'm running 19x10.5 and 19x11 with 305/30 and 325/30. works fine on the ZL1.
Old 05-09-2018, 05:36 AM   #13
likerage
I'm not claiming they are forged. It states clearly that its flowed. I wanted to make the point that your cast comment was wrong is all so there is no confusion.
Anyone have an OEM weight? now I'm curious.
Old 05-09-2018, 07:39 AM   #14
Can'tHave2MuchHP
Drives: Fast
Per RUQWIKR: unmounted front: 26.8lbs, rear: 27.1lbs
Most OEM wheels are heavier due to having to meet lots of standards and safety/crash testing. A true Forged aftermarket wheel is going to be around 20-25 pounds for these cars. I bet some of the manufacturers can make them even less. Cast replicas are going to be heavier than OEM, but would you notice? Probably not.
