05-27-2021, 10:12 PM | #1 |
Drives: chevy camaro ss Join Date: May 2021
Radar Detector Wiring
Question? So watched video on how hard wire a radar detector through the light panel above the rear view mirror, only problem is the wiring harness shows black and purple/white wire to be ground and 12v power but I'm not getting 12v to the purple/white wire. Its the wire harness that plugs into the passenger side seat sensor for the air bag. The air bag light is on but I check all the wires and there's only 1 getting like 2.85V not 12v as needed. Any suggestions?
05-28-2021, 05:09 AM | #2 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
Do yourself a favor and get a piggy back fuse tap and run power to the engine compartment fusebox or the trunk, find a switched circuit. If you hook it to the overhead without a capacitor every time the traction control engages the detector will lose power.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
05-28-2021, 06:14 AM | #3 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Save yourself the aggravation and get one of these. Yeah it's pricey but shoving extra pins into the terminal block is asking for issues down the road. You have a $40k+ car. No need to cheap out.
https://www.gen5diy.com/collections/...tector-harness They also have them for '16-'18
05-28-2021, 07:44 AM | #4 | |
Drives: '20 ZLE Join Date: Jun 2020
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. |
05-28-2021, 10:40 AM | #5 | |
05-28-2021, 10:44 AM | #6 |
BanHamWatch
Drives: 21 ZL1 1LE Join Date: Jan 2021
Tapped into cigarette lighter here
2021 ZL1 1LE
Auto |
05-28-2021, 12:12 PM | #7 | |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
This is exactly how I did my dash cam, after a few emails back and forth they made me a plug and play harness that just plugs into the overhead console for power and you just plug the rest of the OEM connectors to the new plug. Easy to install, easy to remove is needed in future without any hack job. https://www.camaro6.com/forums/showthread.php?t=583468
05-28-2021, 01:26 PM | #8 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
I did the tap into the wires in the ceiling thing on my 2017, and 2018 camaro it worked fine. tried it on my current 2020 version and the didnt work.
Bought a harness from DIY 5gen for the permanent wiring.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
05-28-2021, 02:39 PM | #9 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
In case of Uniden radar detectors, I believe the Gen5DIY units also remedy an issue where the radar detector will shut off if traction control kicks in. It's a little expensive, sure, but well worth the price, especially considering the traction control glitch you will get by tapping into the mirror wiring.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
05-28-2021, 04:42 PM | #10 | |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
05-28-2021, 05:04 PM | #11 |
Gen5DIY harness is the answer. works great
05-29-2021, 07:53 PM | #12 |
Drives: 2018 2ss redline Join Date: Sep 2019
tapped the cigarette lighter with an old phone cord. cost = $0.00.
zero problems. |
05-29-2021, 11:36 PM | #13 | |
Drives: 2019 2SS Convertible Camaro Join Date: Mar 2012
This! I used gen5diy for my escort on my Gen 6. worth every penny! I did the jumper on my Gen5 and it was a pain in the A$$. And you'd be road trip, look up and the detector is off, then your shaking wires while driving, etc. it would only happen once in a blue mood, but always at a bad time.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness K&N AirCharger Cold Air Intake Sound Tube Delete |
