Old 05-19-2024, 06:07 PM   #1
DavoinShowerHandel
DavoinShowerHandel's Avatar
Drives: 2011 Chevy Camaro 2SS/RS LS3 M6
Lingenfelter Clutch Return Spring
Sorry if I picked the wrong section to post this in, wasn't sure where else it might fit.
I know some folks on here have installed the clutch return spring that Lingenfelter makes, I was curious if anyone had any tips to get the spring mounted into the bracket behind the OBD port. I fussed and fought with it a little earlier and just couldn't get it to mount for the life of me.
2011 Camaro 2SS/RS LS3
Mods: Kooks 1 7/8" LT Headers, CAI Intake w/ APEX Race Scoop, Bo White Ported Throttle Body, MGW Short Throw Shifter, Powerbond 25% Underdrive Pulley, Borla ATAK Catback, Full DSE suspension, Bilstein B6 shocks/struts, Yukon 4.11 gears/TrueTrac, 1.25" drop
Dyno Tuned by Brian Turner of Dyno Tune Motorsports
DavoinShowerHandel is offline   Reply With Quote
Old 05-19-2024, 08:28 PM   #2
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I installed it, I don't have any tips but it fought me as well and finally I did get it.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS
Stainless Works Ceramic LTH/HiFlo Cats
SCT X4 Dynosteve,
Hotckis 1" Springs & Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 05-19-2024, 09:09 PM   #3
DavoinShowerHandel
Dang. I appreciate the reply, glad to know I'm not alone in it fighting me at least. I kept seeing everyone say how easy it was and I can't see how. I'll have to get after it again tomorrow. I kept pushing and it'll kinda catch on the edge of the hole, but then it just won't give any to actually go through.
Old 05-19-2024, 09:12 PM   #4
Joe.G
Joe.G's Avatar
I installed it a couple years ago, I may have bent the hook part of the spring a little to make it go In Easier, I don't exactly remember. I know I thought bit was going to be easy and it wasn't.
SCT X4 Dynosteve,
Old 05-19-2024, 10:55 PM   #5
DavoinShowerHandel
I've definitely had the same experience. I've done things that should've been a lot harder, but this is the one that's kicking my hind end. I thought about giving it a slight bend, might end up having to actually do that. Crazy this little thing is giving me this kind of fits.
Old 05-20-2024, 06:46 AM   #6
SlowLS1
SlowLS1's Avatar
I had to bend one end of the spring also, could not get it on otherwise!
SlowLS1 is offline   Reply With Quote
Old 05-20-2024, 07:50 AM   #7
DavoinShowerHandel
Ok, sounds like I'm not the only one who's had trouble then, I'll definitely trying giving it a little bend. Thanks!
Old 05-20-2024, 11:28 AM   #8
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
I use T-Handle hook tools for spring removal and install like this one. They have short and long handles, Can be straight or on an angle.
Mouse330 is offline   Reply With Quote
Old 05-20-2024, 11:41 AM   #9
DavoinShowerHandel
Nice! I hadn't seen these before, I might see if I can find one short enough to use in there, it's a tight squeeze but I might give this a shot.
Old 05-20-2024, 08:26 PM   #10
DavoinShowerHandel
I gave her my very best effort today and managed to punch it through. Thanks for the help & suggestions, everyone!
Old 06-18-2024, 05:12 PM   #11
The Flash
The Flash's Avatar
Drives: Firebird 95, Equinox 05, Camaro 2SS
Installing it is a bit of a chore
I installed mine about 10 years ago... forgot about it until I read your post.
I remember I got a good lamp at the foot well to get a clear, clean view and that helped immensely.
Then I had to muscle the spring in... somehow it became easier by moving the seat all the way back and then 'diving' into the footwell head first, kinda' up-side down.
Attempting to do it upright got me nowhere as I couldn't see the hooking points behind the pedal... but getting myself up-side down was quick & effective.
I'm on the light side of the scale, just about 155-165 pounds and have no previous history with my back (I do have a couple of collarbone and shoulder issues from my motorcyclist daredevil days though) so that might not work for you.
Just make sure you wear tight and dependable eye protection.
The Flash is offline   Reply With Quote
