Old 10-02-2020, 06:34 PM   #1
anth331
anth331's Avatar
Drives: 12SS
E-85
A friend of mine has a 12 mustang and a 19, both GTís He wants me to change over to E-85. On his 12 he said that he had to get new injectors and a tune On his 19 just a tune My car is a 12 2SS with auto and 52,000 miles Iíve gotten a Dynosteve tune after installing my headers Itís awesome. What all is involved changing to E-85 and would it be worth it? Money and trouble wise?
anth331 is offline   Reply With Quote
Old 10-02-2020, 06:39 PM   #2
Rons1le
Rons1le's Avatar
Drives: 2015 Camaro 2SS RS 1LE AGM
No real benefit unless your boosted. IMO
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
Rons1le is offline   Reply With Quote
Old 10-02-2020, 07:04 PM   #3
anth331
anth331's Avatar
Drives: 12SS
Thanks for the information Just headers, Z28 cai NPP exhaust and a Dynosteve tune. Thatís it as for performance mods
Old 10-02-2020, 08:51 PM   #4
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Wouldn't mess with it NA unless your 12:1 or higher on compression.
Bo White is online now   Reply With Quote
Old 10-03-2020, 07:13 AM   #5
anth331
anth331's Avatar
Drives: 12SS
Thanks for all the information. Not going to get E-85
Old 10-03-2020, 10:36 AM   #6
ariZona28
ariZona28's Avatar
Camaro guys shouldn't take performance advice from Mustang guys. They have a hidden agenda. LOL.
ariZona28 is offline   Reply With Quote
Old 10-04-2020, 06:44 AM   #7
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2013 2SS, 2015 LaCrosse, 2017 Z06
There's nothing wrong with adding E85 to any engine. It will give you more power. The bottom line is any improvement is up to what the owner feels is cost acceptable for overall gains.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 10-04-2020, 07:05 AM   #8
07-SRT
07-SRT's Avatar
Drives: 2015 Camaro SS
When I had my 16GT (N/A) I had E85. It only required an injector swap. I also had a flex fuel tune. It was only good for maybe 10 rwhp. Imo it doesn't seem cost effective for a N/A 5th gen.
2015 Camaro 2SS
Cam/Heads/FBO 498/447 SAE
07-SRT is offline   Reply With Quote
Old 10-04-2020, 03:21 PM   #9
Bo White
Bo White's Avatar
How much power it adds depends on cylinder pressure and how aggressive your pump gas tune is. I gained 3rwhp on my stock compression build.
Old 10-04-2020, 04:21 PM   #10
Warship2k15
Drives: 2010 Camaro 2SS
Yep as many have stated not worth it unless you are high compression or boosted.
Warship2k15 is offline   Reply With Quote
Old 10-05-2020, 10:21 AM   #11
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Not worth it on your car
Greenhornet2 is offline   Reply With Quote
Old 10-07-2020, 12:07 PM   #12
TuneAFish
TuneAFish's Avatar
Drives: 2015 Camaro SS M6
Just for the sake of answering the original question about what's involved, as I understand it on a 2010-2015 you have to change fuel lines (E85 can damage our stock lines) and at a minimum boost the fuel pump output and I think the injectors because you need to run more liquid through the system to get the same air/fuel ratio. I seem to remember someone doing a data log and the fuel pump was maxed and possibly the injectors were near max duty cycle. That means if anything wore out you'd be real close to running a lean condition and potentially damaging the engine.
Also in the interest of clarity, if you look at an octane chart, 93 octane is all that's required up to 11.0:1 compression. Since the stock 10-15 engines have at most 10.7:1 (I believe this is true), the extra octane from E85 doesn't do very much (hence the 3HP increase Bo cited).
I have not ran E85, so I am not speaking from actual experience; only what I've read in my own research on the topic before also deciding to pass on it for now.
-Rad Air CAI
-GPI SS3 Cam & BTR Springs
-2" Texas Speed Headers
-AEM Wideband AFR
-3" Full Exhaust w/Hi-Flow Cats & Single Chamber Flowmasters
-McLeod RXT twin-disc w/Aluminum Flywheel
-Yukon 4.11
-Nitto 555 G2
TuneAFish is offline   Reply With Quote
Old 10-07-2020, 06:46 PM   #13
Roader
Drives: Camaro
I’ve ran e85 for about 5 years now. No need to replace fuel lines. I already had a zl1 pump and id850 injectors. My pump started dropping fp in upper band around 500rwhp.
Roader is offline   Reply With Quote
Old 10-08-2020, 07:23 AM   #14
xc_SS/RS
Drives: 2010 Camaro SS/RS
For E85 all you need while stock is the alcohol sensor. Once you start adding mods you’ll need to install bigger injectors and a bigger fuel pump.
My stock pump after 80k miles wouldn’t hold pressure with E85. Got a ZL1 pump and also added 50lb injectors and now with full E85 my duty cycle is like 80-85%.
If you can get your alcohol mix between 30-50% that’s all you really need
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
