03-25-2021, 07:58 PM | #1 |
Stock bottom end to 416
I swapped my valvetrain and heads over from my old build to the new one so this is 376 vs 416.
Kudos to Scott Culbert at Gen 3 Performance and Dyno for getting it straightened out. There it is in black and white(and red and green) difference between stock bottom end and 416 bottom end. Blake Winslett gave me a hand on swapping the LSA injectors out to the FIC 72lb ones since I knew it was gonna be thirsty(which it was on E85, they are at 95% DIC). Thanx to Terry Wilkes for assembling my shortblock at Wilkes Performance. Also Jason Mangum at Texas Speed and Performance on the parts selection on valvetrain and PRC 260s. Cam is 243/255 in both. Red is 93 pump stock bottom end Blue is 93 pump 416 Green is E85 416
03-25-2021, 09:25 PM | #2 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
those are solid numbers.
what rpm will you be shifting at? Sent from my SM-G975U using Tapatalk
Bone Stock |
03-26-2021, 05:40 AM | #3 |
Great results!
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
03-26-2021, 06:38 AM | #4 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Damn 518 on stock bottom end is solid
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
03-29-2021, 04:22 PM | #5 |
Been driving it around some Friday and today. I'm loving the fatter torque curve. I did tighten my 6000 stall up when I swapped engines because I knew the added torque would make the converter stall higher and I was right. I went back to my first 8" stall that I ran before. It stalls out at 5500-5600 now. It should loosen up a touch once I get some more miles on it. You can see the difference in stalls in the dyno sheet. I'm making almost exactly 100hp/60tq more now than the last time I ran this stall. 437/389 was what I made stock bottom end, stock manifold, stock ported heads and BTR3 cam.
03-29-2021, 04:32 PM | #6 |
If it were still a manual I figure it would be 580/510 based on my previous testing between manual and th400.
03-29-2021, 10:03 PM | #7 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Very nice Bo!
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
03-29-2021, 10:49 PM | #8 |
Drives: 15 Camaro SS Join Date: Oct 2018
Crazy how little was gained bumping up to a stroker. Ive always thought this was the case, but you proved it. Thanks for posting Bo. As always, your car is badass!
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
03-29-2021, 11:04 PM | #9 |
Peak HP wise correct. Through the curve is huge. I'm over 40tq in some spots.
03-29-2021, 11:11 PM | #10 |
Clarkstar had the same findings. He has a manual.
https://www.camaro5.com/forums/showthread.php?t=557005
03-30-2021, 06:16 AM | #11 |
Yup, noticed that. The torque bump is very nice
03-30-2021, 08:46 AM | #12 |
Great job Bo!! Badass as always!!
04-03-2021, 03:03 AM | #13 |
People ask how I like the 416 compared to the 376 since all I changed was the bottom end. I tell them it's like giving someone a spin in the car and you can tell the added weight is there. The stroker feels like I had someone in the car with me the whole time with the previous build and they finally got out lol.
04-04-2021, 04:35 PM | #14 |
Drives: 2015 1LE Join Date: Oct 2015
The added torque is always nice to have. I always thought the 416 needs a large cross section area intake runner, larger valve and a large volume plenum intake to make lots of power up top. Kinda like a LS7
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
