Old 07-08-2019, 11:03 PM   #1
PumpinIron
Drives: 2013 Camaro 2SS
What offset do I need for aftermarket wheels?
When purchasing aftermarket wheels (20x9 and 20x10.5) what offset should I be looking for so that the wheels / tires are flush with the fender. Close enough to look good, but not close enough to need to cut or roll the fenders.
The ones I was looking at are 20mm in the front and 40mm in the rear.
PumpinIron is offline   Reply With Quote
Old 07-25-2019, 01:39 PM   #2
Eboelz
Eboelz's Avatar
Drives: 2017 Silverado 2010 camaro 2ss/rs
new here.. been searching and this came up.. would also like a little info.. have a set of 20x9 35mm and 20x10.5 42mm sitting in the garage i was thinking of trying
Eboelz is offline   Reply With Quote
Old 07-25-2019, 05:03 PM   #3
Shakamanno
Drives: 2014 Camaro SS
I have 20x10.5 305/35/20 on rear with 38 offset and fronts 20x9 275/40/20 with 20 offset. Ferrada FR2. No need of fender roll and no rubbing. No issues at all.
Shakamanno is offline   Reply With Quote
Old 07-30-2019, 10:52 PM   #4
Pearlj10
Drives: 2011 Camaro 2LT
Agreed. The 1LE wheel specs of 20x10 +23 front and 20x11 +43 rear are a great starting point. That is what I run now (MRR 017 wheels) and the fronts stick out a slightly more than I’d prefer. That being said, the handling is amazing! Running 275/40/20 fronts and 295/40/20 rears. Not even close to rubbing but not lowered, either. Flame me over the 40s, I’m ready for it!
Pearlj10 is online now   Reply With Quote
Old 10-14-2019, 12:59 PM   #5
Carlos_MRRWheelsInc
Carlos_MRRWheelsInc's Avatar
Drives: camaro
if doing a 20x9 /20x10.5 I would say 25et front /38et rears.
Carlos_MRRWheelsInc is offline   Reply With Quote
Old 10-14-2019, 02:27 PM   #6
G8One2
Drives: 2014 Camaro 2SS
I wish there were a sticky on what fits and doesn't fit. I too have searched and never find anything exact, and the info I come across is always kinda of not complete, leaving me with more questions.
G8One2 is offline   Reply With Quote
Old 10-14-2019, 03:12 PM   #7
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
I currently rotate between 4 sets of wheels, 3 sets are OEM while the 4th is after market, as follows:
1. 21" RPO Code VZP, front wheels 8.5" with a 38 MM off set, tires 245/40/21
rear wheels 9.5. with a 42 MM off set, tires 275/35/21
2. 21" RPO Code VZN (square setup) all 4 corners 8.5" with 38 MM off set
tires 245/40/21
3. 20" 2019 OEM black wheels (square setup) 8.5", 25 MM off set, tires 245/40/21
4. 20" After market ZL1 wheels (square setup) 10" width 35 MM off set, tires
265/35/20
Deputy347k9 is offline   Reply With Quote
Old 10-14-2019, 04:36 PM   #8
Carlos_MRRWheelsInc
Drives: camaro
tires 245/40/21
265/35/20
oh man now thats a list
Old 10-14-2019, 09:29 PM   #9
Deputy347k9
I guess I have a "thing" for wheels. So much that I recently purchased an Autel TS601 TPMS tool. I have on hand 12 MX sensors on hand just incase! Powder coater is delivering my 20"X10" ZL1 replicas this coming Friday evening. There goes 4 sensors and another set of tires! Guess I could have far worse addictions.
Old 10-15-2019, 02:53 AM   #10
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
+43 rear +23 front I have 315s in the rear and they don't rub.
StingrayblueSS is offline   Reply With Quote
Old 10-15-2019, 04:49 AM   #11
G8One2
Are you lowered? Or stock height?
Old 10-15-2019, 11:42 PM   #12
StingrayblueSS
Lowered 1"
Old 10-20-2019, 05:08 PM   #13
Brilei5
Drives: 2015 SS Commemerative Edition
https://photos.google.com/album/AF1Q...ilmcOi4cPugx0d
20 X 9.5 +18 front
20 x 11 +38 rear
Brilei5 is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
