11-19-2020, 08:09 AM | #1 |
Drives: 2010 Camaro SS Join Date: Jun 2020
No audio from radio
I replaced my radio with a used one. After replacement I could only use the radio for making blue tooth calls as the screen displayed a locked message. Yesterday I took it to the dealership to get it unlocked but they told me that while the message was removed the radio wasn't producing sound. I'm able to change stations, view the different menus, etc but no audio comes out. I don't even hear the blinkers turn on anymore and I can't make bluetooth calls. I was wondering if anyone experienced this and if they were able to solve it.
Thanks, |
08-25-2022, 02:04 AM | #2 |
Drives: BNW Join Date: Aug 2022
this is also the sound problem i want to talk about, you can do better for your suonerie gratis sound
08-25-2022, 12:30 PM | #3 |
Drives: ZL1 Join Date: Dec 2016
Makes you wonder if there a problem with your Amplifier.
09-28-2022, 10:17 AM | #4 |
Drives: 307 Join Date: Sep 2022
common parts you should check include; blown fuses, Wiring shorts, Faulting input, or Damaged speakers/wires. It could also be a simple solution, such as the source or audio output device.
09-28-2022, 10:19 PM | #5 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
Yup.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
10-01-2022, 01:40 AM | #6 |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
what happened to the original radio? is the new to you headunit an exact replacement?
as stated above, start with the amplifier |
