06-19-2018, 11:02 PM | #1 |
Drives: 2017 2LT/RS & 2013 2LT/RS vert Join Date: May 2014
What part is this called
Wanting to run dash cam cord in this then down pillar. Can't find any DIY videos. Or ca I just stuff it under it?
06-19-2018, 11:26 PM | #2 |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: Dec 2015
Don’t know if the convertible is different, but on my coupe I was able to stuff the cord under the headliner trim next to the top edge of the windshield, and then pop off the A-pillar trim to run down to the side of the dash
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo GPI VVT SS1 cam and CNC ported heads milled .30 BTR .660 springs, Straub solid bushing trunions GPI rod-mod intake with I-M heat sheild Circle D 258mm Pro single disc 3700 rpm stall converter 169F thermostat & manual fan switch Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft |
06-19-2018, 11:29 PM | #3 |
Drives: 2015 2LT RS Convertible Join Date: Dec 2016
That’s the header panel on a Convertible. You have to peel the cloth top back to be able to take the header panel off to stuff wires behind it. Be careful as the header panel is know to break easily when the screws are overnightened in the busses.
06-24-2018, 10:17 PM | #4 |
06-26-2018, 02:47 PM | #5 |
Drives: 2014 Camaro 2SS RS & Ground effects Join Date: Apr 2014
Krolis, I ran my cord the same as you desire and added an aux plug to the fuse box in the area of the steering wheel, tucked all under the dash so it can not be seen. There are 2 screws under the sun visor. When you pull the visor down you will see small plastic squares. They pop out by using a small screw driver and prying from the right side. Take the screws out then carefully pop the header cover off on that side. Then you pop off the A pillar cover and the rest is easy.
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 |
06-29-2018, 04:34 PM | #6 | |
Didn't even think to look under the visor. |
06-30-2018, 10:50 PM | #7 |
You are welcome, that is what this forum is all about helping one another out. Let us know how you make out.
07-09-2018, 08:18 PM | #8 |
3rd Gen Camaro Aficionado
Drives: '14 Camaro RS/SS Convertible Join Date: Nov 2013
But exactly how do you get the a-pillar trim off? Where do you pull? What holds it on? Mine is nice and tight now, so I really don't want to break it.
-Mike
'14 Camaro RS/2SS L99 convertible - wine country cruiser '13 GMC 3500 SLE CC Dually Duramax - tow pig '87 Camaro - 10 second drag car that runs 11s |
07-09-2018, 11:44 PM | #9 | |
All I did was gently pry the top-most part away from the body and the upper clip will pop free, then do the same with the next clip. It will come out from behind the weather striping.
07-12-2018, 02:33 PM | #10 |
Thanks for the info. What kind of clip is it? Is it the ribbed plastic one that gets ruined if you ever remove it? Or is it actually meant to be removed and replaced?
-Mike
07-13-2018, 12:40 AM | #11 | |
They are those metal blade type that I guess you can say are meant to be removed and replaced. I removed it at least twice as I upgraded my dash cam.
01-27-2019, 02:24 PM | #12 |
Drives: 2012 LT1 RS Convertible Join Date: Jan 2012
Good information in this thread as I just got a dash cam to install. Does anyone have the rear camera also and if so how and where did you install that. Mine is a 2012 vert.
02-04-2019, 10:47 PM | #13 |
I attached mine just above the license plate, ran the wire behind the plate. There are holes behind it that lead to the underside of the car. I then ran the cable along side the wires next to the frame of the ca. Once I got to the front of the door I ran it through where the wires for the power windows go through (black grommet) Then up inside the "A" pillar and across the head liner to the camera.
03-22-2019, 09:49 PM | #14 | |
I finally got around to taking off the A pillar trim. Even though I was very gentle, the trim piece itself and one of the blue clips broke. Anyone know where to get those blue clips? Also, a little block of gray foam (like a spacer) fell out. Does anyone know where that's supposed to go?
-Mike
