09-10-2020, 06:58 PM | #1 |
Drives: 2010 Camaro SS Join Date: Feb 2018
Over spinning procharger
Is anyone here overspinning their procharger and by how much? I’m making good horsepower but have more than enough motor to handle more. I already have my f1a-94 maxed with an 8.25 crank damper and 4 inch supercharger pulley. I just want another couple psi but don’t want to hurt my procharger either. Just curious of who’s doing it (if anyone) and what your experience is. Thank you!
2010 Camaro 2SS/RS - 416 stroker, F1A-94 procharger, BTR blower cam, Big Red race valve, AGP intercooler, Alky dual nozzle kit, ZL1 fuel pump with DSX Aux pump, DSX flex fuel sensor, Bosch 210 injectors, Mcleod RXT1200 clutch, MGW flat stick, Tick Performance Level 3 trans, DSS 3.5 aluminum driveshaft, Strange S60 rear, DSS 1400hp axles, Texas speed 1 7/8 headers, X-pipe and MBRP muffler delete, BMR lowering springs, BMR trailing arms and toe rods, Poly motor mounts, RevShift trans mount instert, rear sub frame braces, Tuned by Joey at Pure Fabrication in Panama City, FL
09-10-2020, 10:10 PM | #2 |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
There is a little room. But how much power are you making currently?
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
09-11-2020, 06:56 AM | #3 |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
Badazz setup my friend!
Call Procharger and bend their ear. At least you can find out what RPM your supercharger is rated for and with your current crank and pulley sizes they should be able to estimate the output. Maybe it is time to step up to the F-1X
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
09-11-2020, 10:41 AM | #4 |
I’m making 985 on E. The f1a-94 is rated at 74,000 rpm. I’m pretty much right on the max right now. That’s kind of why I’m asking. Thanks for the replies guys. I’ll definitely call procharger.
09-22-2020, 09:44 AM | #5 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
Man I wish I could find a 8.25 lower pulley for my 12 rib setup.
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
09-22-2020, 10:06 AM | #6 |
I’m only 8 rib still and have no belt slip. If I ever upgrade though I’ll be looking into probably going cog. I just don’t know if I want to change the whole set up just to fit a bigger procharger on there and lose so much low end and drivability. That’s why I’m trying to get all I can out of what I’ve got.
09-25-2020, 04:13 PM | #7 |
Drives: 1999 Trans Am Join Date: Jul 2009
9.0 lower, 3.55 upper on a f1-a 94, revving to 7000rpm.
Have many cars over spinning the blowers. They don't dome alive till you do. |
09-26-2020, 09:19 AM | #8 |
Very happy to hear this man. Thank you! You're overspinning the hell of her. I will definitely be going smaller on the pulley in the near future.
Thread Tools | |
