04-09-2018, 08:33 PM | #1 |
Drives: 2011 camaro 1ss Join Date: Jul 2017
Tow Point
So after looking on the internet for awhile I realized the cost for a tow point is absolutely ridiculous! Maybe I’m wrong and someone can show me a cheaper option than forking out 100 dollars for something so simple... anyways! So being a Cnc Machinist and working in a fab shop I ended up making my own! Haha
Made out of 3/16”x3” hot rolled flat bar and 1/2 bolts/lock nuts/ washers! Total cost $10 and some change! Sent from my iPhone using Tapatalk |
04-09-2018, 09:19 PM | #2 |
Drives: 2013 Camaro SS Join Date: Oct 2016
So simple but great execution.
04-10-2018, 06:25 AM | #3 |
04-10-2018, 08:30 PM | #4 |
Drives: 2015 Z/22 Join Date: Aug 2015
How much are you selling these for...
04-10-2018, 10:31 PM | #5 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Now make one for the rear and I'd buy one!
Orange Krush II
05-04-2018, 01:17 AM | #6 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
but why?
05-09-2018, 11:25 AM | #7 |
